Master
- Posted on Jun 20, 2010
Re: Abit kn9 sli, my problem is this, when i turn my pc...
Are you sure the 4 pin connector is going in correctly? Some motherboards have an 8 pin socket, and the connector can be placed in improperly. The symptoms you describe indicate a dead short on the power line when plugged in.
tried the connector a few times and each time i get the same result. someone suggested it may be the cpu at fault as its the connector for that which is causing the problem.
im just not too sure.
