Hi there Vriddick
To adjust the seat for height, there is a locking bolt on the seat post, below the seat. Loosen this and the seat should drop down the hole. Lift it up to your specified height and tighten up the bolt. You can also use this method to adjust the direction of the seat in relation to the handlebars, left or right.
If you need the seat adjusted for its angle. Under the seat itself are two bolts clamping two large circular bits of metal, undo these bolts and tilt the seat downwards or upwards, retighten when you have it just right.
