Question about Dishwashers
I have a kenmore ultra wash dishwasher. For some reason, I am unable to select any of the cycles with the exception of ''Quick Rinse''. All other buttons work. The lock is not engaged. Unplugging the dishwasher and plugging it back in does not solve the problem. I press one of the cycle buttons and nothing happens, no lights light up, etc. Kenmore Ultra Wash Dishwasher Model: 665.1374* / 665.1384*
  • spam228 Jun 29, 2010
    Nope, you can hit the "start" button without selecting a cycle and it will choose the "smart wash" cycle by default. It's a temporary workaround.
  • bcry4419 May 22, 2014
    Yes it does that
Nothing so far. The press Sanirinse, high temp buttons as suggested got all the lights on and the machine cycled through all the programs, but the problem remains.
Posted on May 22, 2014
I have the same problem tonight!!! Did you find a solution??? matts268@comcast.net
Posted on Jun 29, 2010
    Not yet. The sani, high temp button pushes worked to force the machine to run thru cycles but problem persists
6ya staff
SOURCE:
Kenmore ultra wash dishwasher
Replace control board.
Nov 15, 2017 | Dishwashers
I am trying to clean earthen pottery plates in my dish washer and after washing half of the plates disappear.
The Kenmore PRO also has an Ultra Wash Filtration High Energy Filtration System that helps the majority of us with hard water. It features 2 spray arms, and a Turbozone that blasts away the most gunked up items you can make a mess on.
The Kenmore PRO also features 6 cycles. The High Energy Smart Wash Cycle is the most advanced and versatile. It actually senses the load size, soil amount, toughness of soil and uses minimal water and energy. The Smart Wash Cycle runs from 110 minutes to a max of 194 depending on toughness of soil and uses from 4.2 gallons of water to 6.9.
The Pots Pans Cycle also makes some adjustments depending on soil level and takes from 140 minutes to 203 minutes to complete. It uses 4.8 to 6.9 gallons of water.
There is also a self-adjusting Normal Cycle that runs from 110 minutes to 193 minutes and uses 4.2 gallons to 6.9 gallons of water.
The Kenmore PRO also has a self-adjusting China Gentle Cycle that provides a light wash and gentle dry for delicate items and runs from 105 minutes to 194 minutes and uses 4.2 gallons to 6.9 gallons of water.
It also has a 1 Hour Wash that runs for 58 minutes and uses 8.0 gallons of water and a 15 minute Quick Rinse Cycle that uses 2.1 galllons of water.
The Kenmore PRO also has 5 other options that are additional to the Cycles. Each option adds time and water to the selected cycle. They are:
TurboZone, HI Temp Wash which raises the water temperature to 120 degrees F, a Steam Sanitize which raises the final rinse to 155 degrees F, a Top-Rack Only Option, and a Heated Dry Option.
The Kenmore PRO also has a Delay Option that allows you to run the dishwasher on off-peak hours and delays the start time up to 6 hours.
I have not field-tested all these options yet, becaue I am such a skeptic -- and picky about my dishes, I usually go ahead and always use the TurboZone, the Hi-Temp Wash, the Steam Sanitizer, and the Heated Dry Option. But, hey if you are plunking down $1500 for a dishwasher--you should make use of all your options. I'll keep this review up-to-date as my dates with the Kenmore PRO progress with dinner parties and my very precious china, but for now (mostly because of the "ClangBanger") our good china is safely stored in the cabinets.
Aug 16, 2011 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Kenmore 655 Ultra Wash- dishes not getting clean and have a residue on them when done washing. Arms appear to swing freely.
Does the dishwasher drain the water properly at the end of the rinse cycle. Meaning, is there any leftover water at the bottom of the dishwasher.
Sep 01, 2009 | Kenmore Dishwashers
Washer will not go to the rinse cycel.
check cold water line...onthejob,,,im assuming no rinse cycle only..onthejob,,,no mater the cycle
Jan 31, 2009 | Kenmore Elite 45986 Front Load Washer
Intermittent problem, unable to select normal wash cycle/start
restart curcuit board sequence
push start hold down air dry and start until lights blink and machine starts then it should work normal
most dishwashers have an instruction booklet behind the botton panel that is nearest the floor you wll have to remove the panel it has a couple of screws. the booklet should be there unless installer took it.
If you omly replaced the front panel board then you may have to replace the circuit board inside the door. It works like a mother board in a computer. Good luck
Nov 17, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore Ultra Wash rinse agent not draining
I used to think the same in my dishwasher, but come to find out it actually lasts for a few months so it only uses drops at a time..
Mar 03, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore Ultra Wash Dishwasher - Blinking Quick Rinse Light
I had the same flashing light problem first the normal wash flashing light then the others. I tried shuting of the breakers but nothing. I tried resetting the panel by pushing normal wash and heated dry simultaneously and nothing. So I took the six screws holding the front panel out and unplugged the ribbon type wires and plug and unplugged it several times to help make a better contact and I was able to get it to work right away. This may not work for all but I worked for me. It is very easy to do and it's worth a try if you're having the same problem. It took me less then 10 minutes.
Oct 16, 2007 | Dishwashers
My Kenmore diswasher gets stuck between the quick rinse and drying cycle
I am having the same issue as described above. I think it is either the timer, thermostat (temp assure), or thermostat (temp boost) that needs replacing. The dial gets stucks in both the wash temp boost cycle and rinse temp boost cycle. However, I don't have a picture of the temp assure or boost part. Does anyone know how to fix this? Thanks. -Bill
Aug 31, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
1,006 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
