Question about KitchenAid KCMS145J Microwave Oven
Our microwave looks and sounds like its working but it isn't heating anything. Is it time to replace or a repair job?
    New Friend:
Same problem with mine. Any advise on how to address problem would be appreciated.
Posted on Sep 27, 2010
6ya staff
SOURCE:
I have a KitchenAid microwave model # KCMS185JSS. Everything works except it stopped heating up anything. Is there a separate fuse for the microwave heating? Where is it? can I fix this myself?
Sounds like the microwave's magnet tron (join two words together this page will not allow the correct word) the has gone down. They only last a short time depending on use. Not a great job to do on your own (if you do not know what you are doing) the part cost about 35pounds so most cheap microwaves are not worth repairing, if it is an expensive one it may be worth paying for the repair.
May 26, 2014 | KitchenAid KCMS185J Microwave Oven
Gas oven isn't heating up, the heating element is working but the rail isn't lighting, what needs to be done?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 27, 2011 | Maytag Microwave Ovens
Own Whirlpool microwave model MH7100XY, everything works on it, however it does not heat anything, heard a small pop and after that it does not warm or cook anything?????
The pop sound is an indicator the magnetron is gone that heats the food. It is cheaper to replace the microwave oven than have it repaired.
Mar 19, 2011 | Whirlpool MH7140XF Microwave Oven
I got this Sunbeam SGB8901 microwave that doesn't heat anything. It turns on, rotates drink or food, and it sounds like it's working fine, but once the timer counts down, you pull out the drink and it's...
That will either be the magnetron or the power transistors inside having failed. If you get lucky a repair shop might be able to fix it reasonably but usually it is time to look for a replacement as the repairs cost more than the new one.
Jan 24, 2011 | Microwave Ovens
Microwave is on but won't heat.
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician.
You can now purchase a new microwave for about fifty dollars at walmart so that may be cheaper than having a repair tech work on it.
Aug 20, 2009 | GE JE1540 Microwave Oven
Microwave doesn't heat anything
This more than likely is the magnatron,< heats food >, making noise and not working. it isn,t really easy fix and can be done if you get part and experienced person to walk you through it. Most GE magnatrons have at least 5 yr warranty and if it isn't that old call them first.
Apr 23, 2009 | GE JVM1320 Microwave Oven
Microwave isn"t heating
Test the high voltage capacitor,the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be alloweddischarge before testing, or you risk to get electrocuted, even ifpower is off. Capacitors can get discharged by shorting their twocontacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Mar 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave partially heats
its time repair will cost more than a new one
Dec 01, 2008 | KitchenAid KCMS145J Microwave Oven
Panasonic convection oven,grill and microwave
Sounds like the microwave unit (magnatron) has failed. This will happen if the microwave has ever been used without anything in there to absorb the energy. It basically cooks itself.
Unless you are particularly fond of this unit, it is usually cheaper to buy a replacement than order parts and repair.
You could phone a few local repair centres and ask for a quote , but weigh this against the next thing likely to fail.
Worth repairing industrial models, not really worth repair to domestic models.
Hope this helps you.
Jun 13, 2008 | Microwave Ovens
KitchenAid KCMS145J Microwave Oven Logo
48 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jerry Greenberg
Jerry Greenberg
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
