Innovage Speaker/Caller ID* LCD Touch Panel...
The Caller ID displays _ _ _ _ _ _E_ _ _ _ _ It does not display the number. Does anyone know why????
Might be the IP funtion is on. this is not available in the USA. press SET/SAVE, press Up to select "SET 4 AUTO IP", press SET/SAVE to select, press UP to change setting, press SET/SAVE to confirm. if you'd like a copy of my manual for the phone, email me at [email protected] and i will send a copy in 2 different formats so you'll be sure to be able to open at least one of them. hope i helped.
tammy
Check your phone to make sure it is set up properly. Open the back of the phone by pressing your fingertip on the small lever that opens the battery area. The battery cover will come off in your hand. Insert three "AAA" batteries into the back of the phone so you can use the night light feature. Replace the battery cover by sliding it into the battery area and clicking it into place with your fingers. Connect the phone to the telephone phone jack by connecting one end of the wire to the phone and another end to the wall jack. Connect the handset to the phone by inserting the end of one end of the curly phone wire to the handset and the other end into the side of the phone. Listen to the dial tone by pressing the speakerphone or picking up the handset to make sure your Innovage LCD touch panel phone is connected.
Review calls you missed. Use the up and down arrows on the Innovage LCD touch panel phone to view the caller ID phone numbers.
Use the night light to view the Innovage LCD touch panel in the dark. Slide the switch on the front of the panel to turn the night light function on. Slide the switch to the off position to turn the night life off.
Adjust the volume on your speaker by selecting the speaker loudness that you want. Press the hands free button once and press the "Delete" button. Choose a loudness from one to four.
Press the hold button on the front of your Innovage LCD touch panel phone. This will activate the hold function when you are on a call and it will allow music to play while someone is on hold. The hold music is built in to the phone and will automatically play when you press hold.
Save a phone number as a VIP number on your Innovage LCD touch panel phone. Press set and save when an important number comes onto your caller identification. This makes it harder to delete the phone number by accident.
