Looking at the schematic I see 2 possibilities:
1. I think the most likely cause is a failed "limit switch" aka "thermal fuse" aka "temperature cutout". For each oven there is a limit switch that feeds power to both elements. So the upper limit switch is probably tripped which would kill power to the upper bake and broil elements. The limit switch is usually located on the back wall of the oven cavity.
2. There are a relay board for each oven. Be sure you changed the right one.
Best Regards,
Bruce
www.fixyourboard.com
well, as I continue to troubleshoot, I see that it can not be the baking element. (from the bottom of the oven) I switched the bottem oven bottom element with the top oven bottom element and it still did not work. so maybe its about the broiling element?
does that mean if its the "temp cut out", the entire oven needs to be pulled out to repair? also, the only relay board I see is in the top. I see no other relay board. there is another board but not like the relay board. where would the other board be located?
