Check for bad solder joints on the power supply baord first, especially around C310 (GRAY cap as shown in my pictures)
http://s807.photobucket.com/albums/yy352/budm/Westinghouse%20LTV-32W1/
Repair,take the tv aparts.The board where the power a/c cord plug into it.That the power supply board.Replace the power supply board will solved thiss problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Testimonial: "Thank you for the good advice. I'll let you know how it turns out!"
Yes,but make sure all the screws are totally lose and should carefully remove the back cover.When u remove the power supply board,u don't have the board part right at hand take notes and draw a sketch what u take out,so u remember what u take out and put all the connections back the same exactly.When u buy the refurbish power supply board compare the website board picture to ur actual board make all the big component are the same when u order it,like ICS chips,Power Transformers extra...
OK, I have found a couplke of suppliers for the power supply board. Is there anything I need to know about opening up the tv? Is it as simple as removing the 8 screws from the back panel and separating the back from the front?
Thanks for any help...
I have never opened up a TV before; but I have opened up a few computers. I think I'll give this one a try. Thanks for the advice on taking notes - I think I'll take a few digital pictures to remember "what goes where" for reassembly. BTW I found a supply board at Discount-Merchant.com. They seem to have a fairly good reputation. Thanks again for your advice and help.
