I believe that this is a high-temperature error. so, you might need to move the printer to a cooler room or lower the temperature of the room that the printer is in.
Service Call
181: Error
182: Error
183: Error
184: Error
185: Error
Option unit I/F error
(181 = Duplex Unit.
182, 183, 184, 185 = Optional Tray)
Does this error recur?
Yes
Restore the power.
Check to make sure the contact points of the connector and replace the optional unit
i got that error on the first day i got my oki c5950 it was a result of a paper jam in the fuser unit, i removed the jamed paper but the error was still there, i contacted oki support and got a detailed explanation on how to fix this error with a patch file, so if u or anyone out there r still having that problem send me a mail on [email protected] and i will forward u the info.
good luck
We had a similar problem with an Oki C7300. It was reading "Fatal Error 121" on the display.
We fixed it by simply unplugging the printer from a surge strip and plugging it into the wall directly. After that, the error went away and has not come back.
Error 020 is a ROM dimm error, could be as simple as reseating/replacing Rom Dimm or a expensive main PCB, you need to get hold of a oki dealer, contact oki to find closest OKI repair agent. www.oki.com
