White/black is speaker positive white solid is speaker ground front and back ground gray/black is speaker ground front and back the solid black wire is battery ground
The writing was on the wall (pardon the pun) in 2008 when our founder designed and released the first In-Wall speaker. 5 Ranges and 9 years later, In-Wall and In-Ceiling Speakers have evolved and morphed into Hi-Powered In-Wall systems with Glass fronts never seen anywhere in the world before. Beauty and Grunt! Front speakers (some with inbuilt Centre Speakers) have been designed mainly for high powered Hi Fi and Stereo application providing clean, accurate balanced performance with deep, strong Bass.
You need of any our Technical Support agent. Please call Technical Support team at +44 203 880 7918 our experts are available 24/7 by phone.
You have a possible fault in your wiring of the speakers, the Phases of the speakers are crossed over resulting in cancelling of the low frequency- bass frequency. Hence please reconnect the speakers front and rear with the positive/ negative to the corresponding positive and negative of the speakers.If you are unable to fix the marking of the polarity use 1.5 Volt cell to connect to the speakers , if the speaker moves up the terminal on the positve of battery is positive. reconnect and test with a good bass song for result. Helpful. Good day
Don't use the wire that is already there. Sometimes cars have their own amplifiers for the back speakers to help boost the bass. Lay out seperate wires from your radio to the speakers.
Both the bass boost and the gain generally do the same thing, except the bass boost is essentially "additional gain" at a particular frequency (in this case, 45Hz). I would suggest lowering the bass boost (10?) and adjust the gain. Honestly, you may have to play around with both settings until you find a happy medium. There is going to be a maximum the amp can provide no matter how you get there. Hope that helps!
Check the wiring of the woofers. If one speaker is wired improperly, it can cause the loss of bass and will make the woofers bottom out easily. Check inside the enclosure at the terminals and at the speaker.
