Dometic - Rm2604 gas/electric has a cold freezer but not fridge
SOURCE: AC,DC, gas RV fridge Dometic
You more than likely need to replace the control cable between the upper and lower board. It comes as a kit with the upper board. You can also do a bypass test by unplugging your thermoster from the circuit board. The thermoster is the temperature control for the refrigerator nothing to do with the freezer.
[email protected]
www.coachtech.info
734 777 6432
SOURCE: magic chef gas/electric rv fridge
Mod. R47 gas RV fridge 1973. It lights and gets cold (sometimes below freezing in the bottom of frige) then it starts to warm up above 55, but the flame is still burning high. I try to turn it down with the fridge thremostate and it stays the same. Is it the thermostate? If so where can I order one?
Jerry [email protected]
SOURCE: Freezer working, fridge isn't.
It is possible that your cooling unit is failing due to a blockage. The solution used to cool starts at the top of the fridge and works its way to the bottom. If there is a blockage in the cooling unit it could produce the symptom you have explained.
SOURCE: I have a Dometic RV fridge that wont get cold. it
It sounds like your cooling unit is going out. Here's a couple of things to check. Do you smell any ammonia when you open either one of the doors? When you look at the rear of the fridge, do you see anything that looks like rusty water that has run down any of the metal tubes and dried up? If the answer to either one of these is "yes", then youll need to start looking for a new fridge or replace the cooling unit on the one that you have.
SOURCE: DOMETIC RM 1350 FRIDGE GET HOT AND COLD
Ok, I realize I'm a little late on chiming in here, is this unit located in a slideout, and/or the top outside vent is in the wall not a roof located vent?
If so then the issue is that there are fans that are necessary to circulate air thru the hot coils. And there is probably a malfuntioning thermostat to turn these fans on/off. I had this issue with same fridge in a Gulfstream motorhome, and the temporary fix was to pull the faston connectors off the thermostat and tied them together with a 12V fuse, and taped it up with electrical tape to keep it from shorting on fridge chassis and parts. Replace the thermostat at your conveniance, as these fans are now running whenever fridge is on, and will run your batteries down if not plugged into shore power.
According to the manual the following is the most likely items to cause that failure. But since it is only in the frigerator section and not the freezer section it could be the lower circuit board.
LP Gas
Orifice
Flue Baffle
Flue Tube
Burner
Lower Circuit Board
