Question about Ertl 580 Super M Series II Tractor
I have a 580 super E it slips in forward gear but not in revers. this happened two times before and each time the filter was plugged with black material but after cleaning the filter it was fine. This time the filter was not plugged so I thought that the clutches must have failed. I pulled the trany, tore it down and inspected it, it looks like new. I discovered that there is only one clutch pack and they look perfect, no wear, no hot spots. It also started getting hard to move the lever into revers when it started slipping, I don't know if it's related? I did notice that there is a lot of metal in the oil and am concerned about where it and the black material is coming from.
    New Friend:
Was that the power shuttle that you broke down? If so, is it a Borg Warner velvet shuttle. I have a 580K and mine started slipping like that in forward and finally lost it completely. It had a strong reverse though.
I had to pull the power shuttle and replace the forward clutch disks. The stuff in the oil is probably the fibers from the friction disks. There are seven forwards disks and what happens in these shuttles is the Belville plate or washer breaks under stress and then wreaks havoc on the clutch disks.
What you are describing is exactly the way mine did. I put new forward dicks in and everything was fine then.
You said the disks looked new when you inspected them. You will see the reverse disks first and then as you go deeper into the shuttle you come to the forward disks. You may have been looking at the reverse plates.
My reverse plates also looked good but when I got to the forward plates they were burnt, scarred and very thin. Not much left of them. Check the forward disks, I bet that is where you will find your problem.
There are some pressure stall tests you can run to determine exactly what is not working properly.
Hope this helps and good luck.
Tim
Posted on Feb 09, 2011
6ya staff
SOURCE:
Hi i have a 2000 ford super duty i was plowing snow today and it started slipping in forward gears but revers worked fine then i shut it off and let it set for 4 hours and then we started it and it drove...
Not likely. Chances are that while plowing snow, you overheated the transmission, causing the forward clutches to slip. Regardless, you should prepare to replace or rebuild it, keeping in mind that if it is going to be severe duty, such as snowplowing, you will want to add a transmission cooler as well as beefing up your internals. If it slipped once, it will surely do it again, until you lose all forward gears. It will still work great in reverse, in most cases.
Jan 19, 2011 | Ford F-250 Cars & Trucks
Case 580 super l stops as i drive it forward
What is the last thing that happened before you noticed there was a problem?
Jan 13, 2011 | Ertl 580 Super M Series II Tractor
Some times it slips in revers and takes time to go forward and allready check transmission oiled
DOES TRANNY FLUID SMELL BURNT?
IF SO THEN U WOULD NEED A TRANNY OVERHAUL
Aug 09, 2010 | 1997 Chevrolet Suburban
I have a 96 dodge with a 46 rh trany 4 speed. tanny started acting funny wouldn't come out of second till i moved tne gear shifter and revers is slipping barley grabs. did a filter change and after about 5...
the tv cable may need ajust--bands also--trans is part electronic-governor area--do a scan of truck and pick up a repair book @store or library--dont forgit ur the gears r old with mucho miles
Feb 01, 2010 | 1996 Dodge Ram 1500 Club Cab
Transmision wines and slips 1st, 2nd, revers mybe drive
Sure sounds like the torque converter is bad to me. Usually after the fluid gets hot, this problem shows up. Specially since it's in ALL gears......sorry o;(>
May 26, 2009 | 1988 Ford F 150
Ertl 580 Super M Series II Tractor Logo
2,422 people viewed this question
Top Ertl Toys Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Tom Chichester
Are you an Ertl Toy Expert? Answer questions, earn points and help others
