Plow and Hearth Topsy Turvy Tomato Planter Logo
Posted on Jun 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Topsy turvy tomatoe planter
What are styrofoam cut out for in the bag?
Anonymous
Level 3:
  • Master 43,501 Answers
  • Posted on Aug 27, 2010
Anonymous
Master
Level 3:
Answers
43501
Questions
0
Helped
10835323
Points
101584
The styro foam goes in the hard plastic part and is split to slide the plant into and hold the plant in place...it also serves to plug the bottom to hold the dirt in place...
heatman101
I just noticed a (I think) Tomato worm on my plants but dont know what they look like so its a guess. How do I get rid of them?
I use seven dust on my Tomato vines when I see worms, cut worms or horn worms. Seven dust will take care of them. Wash Tomato's well before eating.
Aug 03, 2017 • Garden
2answers
How to reuse products
Small bags are great for storing halves of peppers, onions, tomatoes
Isit possible to dep freeze tomatoes? If so, how?
I freeze small ( cherry / grape ) tomatoes all the time just wash and put in ziplock bag. Only good for cooking soup. I would dice larger tomatoes before freezing.
1helpful
How do I use this salsa strainer I was given? I use the apple screen with cooked apples. Do I need to cook the tomatoes before I strain them? Thanks!
No; generally, salsas hardly ever require cooked tomatoes, and raw tomatoes are soft enough that pretty much all strainers are capable of handling them. You could blanche them to remove the skin (a tricky process I won't describe here), but that's about as cooked as they usually get. If you are concerned about the strainer's ability to handle the tomatoes, just cut them in half or into quarters, and you should be all set!
Hope this helped! :)
My topsy turvy tomatoes have somthing wrong with them one has a hole in it about 1/4 inch around and another has 4 small holes in the bottom of it, also this may be normal but the bottom of the plant...
The "warts" are perfectly normal. The holes could be normal or it could be bugs or a worm. The bugs or the worm are often the very same green color as the leaves and are also undetectable. Check the undersizes of the leafs as that is often where they like to hide.
heatman101
Having problems securing masonary Bit on 3/8 Black&Decker Drill 7
If it's an inexpensive bit, odds are it's spinning in the chuck. If the chuck key can't tighten the jaws well enough, you'll need to borrow or buy a different drill (or you could replace the chuck).
If you bought an SDS bit (one with slots milled in the shank), you're best off buying a bit made for a standard drill. It's not impossible to get a SDS bit to chuck into a standard drill, but it's difficult and they often slip loose during drilling, messing up the hole.
Take care!
Andrew is ordering the top soil to fill the planter. topsoil is delivered by the cubic yard, and cost $43.00 per cubic yard, tax and delivery included. the determine the cost for the planter.
How big is the planter, what are its demensions. Figure out how many yards in the planter, Right? Either full yards or partial. Or you can buy the top soil in bags, start filling the planter, and when you over fill and spill on the ground you have the right amount, Also you must ask are there plants in the planter, because they will take up some room with their roots.. Good luck...By the wayis this a left handed planter or a right handed planter, ????
Top Plow and Hearth Garden Experts
Jay Finke
Jay Finke
john h
Are you a Plow and Hearth Garden Expert? Answer questions, earn points and help others
