The microwave runs with the door open. Goes off as usual when the door is closed, but when door is opened the light goes on and the turntable rotates. We don't know if the microwaves are activated when this happens. The oven works normally when door is closed and time/power are programmed in. It stops at the end of program, but when you open the door, it comes back on.
This is usually caused by either a bad door switch, a loose door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
SOURCE: sharp R-1871 microwave/convection oven. Microwave will not work
This may be due to the microwave section not working. Check the high voltage diode if it is ok, replace the Magneton.
SOURCE: Frigidaire FMT 148GP Microwave oven. Turntable
1. the motor to rotate the glass table in the micro wave may have stop working or the switch to the motor is defective.
I have the same problem with a GE Spacemaker XL1800. I talked to GE and there are two door switches. Which one is likely to be causing this problem and should be replaced on this, the primary or secondary?
