Toshiba DKT-2010 Corded Phone Logo
Anonymous Posted on Jun 16, 2010
I just wanted to find an on-line manual for my toshiba dkt 2010
Anonymous
Level 3:
  • Toshiba Master 6,487 Answers
  • Posted on Jun 16, 2010
Anonymous
Toshiba Master
Level 3:
Answers
6487
Questions
6
Helped
1557156
Points
18452
Testimonial: "Thank you!!! That was fast and accurate. Wonderful! -e"
Create a voicemail for toshiba DKT 2010-sd
Hit your main voicemail interrupt greeting by pressing pound enter box 999 enter password usuallu 999 or 999997 but could be anything listen to prompts ti create mail
Does teh DKT 2010-sd have a PRI card slot for voip
Since a DKT-2010 is just a phone that attaches to a Toshiba Key System, it's hard to say.
PRI and VoIP are two entirely different protocols. PRI is delivered on two pairs of wires and it contains up to 23 circuits and a data channel. It requires a card in your system, a DK, CTX, or CIX Key service unit.
VoIP can be delivered via an Analog Terminal Adapter, or directly into the KSU if you have a CIX-100 or higher system. Likewise, faxes are deliered on trunks to analog stations, or it just requires an analog line to receive. It can work within your system or outside of your system.
If you look at the manual, starting at page 21-23, this will give you an idea of the capabilities of a CIX system. http://cdgenp01.csd.toshiba.com/tsd/docum/gen_desc/CIX/CIX-GD-ALL-VF_E.pdf
Carl
1helpful
2answers
How do you program a Toshiba DKT-2010 phone to ring
Ringing is a system program, not done at user level. However not that hard it is done in program 81 and the manual is here.
http://guides.idacomusa.com/
1helpful
Set the clock
The link below should provide all the info you'll need.
click here
Conference calling
press the cnf/trn button dial an extension or an outside line and hit the button again after that call connects.
Toshiba DKT-2010 SD acts only as a speakerphone
The Phone has to be replced or sent out for repair. It's a hook switch problem. It's Cheaper to just the phone off Ebay.
4helpful
2answers
Having trouble with a Toshiba model, Need to fix time .
I have DKT3010, so it might be the same, to change time in mine I press Intercom, #652, HH/MM/SS #. It changes it on all of the extensions.
Top Toshiba Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
