You can open the ports of your belkin wireless router by accessing the router setup page. First make sure you have all the port numbers (TCP/UDP). Here is how you can access Belkin Setup Pagethey have also explained how to troubleshoot wireless g routers
Once
you have all the wireless settings of the router, you are ready to
connect the play station or the x-box to the wireless network.
X-BOX
On the x-box you will need to connect to the wireless network now.
Open the main Interface of the X-Box.
1. In the Xbox Dashboard, go to My Xbox and open System Settings.
2. Select Network Settings, Configure Network.
3. On the Basic Settings tab, select your wireless settings.
4. Select
the name (SSID) of your wireless network. If your router isn't
broadcasting your network's name, select Specify Unlisted Network and
enter the name.
5. If your network has wireless security, enter your WEP or WPA key.
6. Try to connect to Xbox LIVE again.
Trouble connecting to the internet on X-box ,Play station or WII ?
You
can try to reduce the MTU settings on the router. if the MTU on the
router is set to 1500 then change the MTU to 1365. Also you will need to
open the ports on the router.
For X-box port numbers are - 53, 80-88, 3074 .
