I know the combination f my samsonite soft side flite luggage's combination padlock, its not working on that now. I tried 000 also. It didnt work either. I tried many combinations and now it got stuck on one side and I cant pull out the shaft. I am in mumbai, maharashtra, India. Please give me a solution
Added: I understand you have tried some steps to clear the combination lock. Check this web page to make sure you have tried all the possible options:
http://traveltips.usatoday.com/reset-samsonite-3digit-builtin-combination-lock-61343.html
(Copy and paste the web address above into your browser to get to the right page.)
Hello, Drjayapanick -
I checked the Samsonite web pages to try to find information for you.
Go to this web page (Contact Us information for Samsonite):
https://shop.samsonite.com/contact-us
On that page you can use the form to send an email regarding repairing the combination lock on your luggage.
Or, you may be able to find a business in Mumbai which sells Samsonite luggage, where you can take your bag to find out where you can have the lock repaired.
SOURCE: I have a Samsonite suite case that has not been
You can open combination locks by pulling on them and then rotating the rings until you feel the mechanism "give".
I'm not sure if this would be too successful with a suitcase but it is worth a try. Use a screwdriver to gently pull along the axis of the lock and rotate one furthest away from the catch.
Rotate it until it goes slack and then feel for the next one along and repeat.
Continue until all the tumblers have loosened, when the lock should open.
Some patience and practice needed.
