Double check to be sure drive levers are fully engaged. Go down and up a few times. If problem persists have Hoveround come and check it out. One of the drive motors may have shorted out when you continued driving with gravel in the wheel.
I have the same issue. The lights flash from left to right every 2 seconds or so. Once or twice when it powers on it didn't fault but as soon as you move joystick forward the error comes back with a quiet click from at least one of the motors.
Not much info to go on, but you may be in Lock Mode. On a VSI the Profile LEDs scroll left to right.To Unlock a VSI: Push joystick forward until beep, then pull joystick back until beep. Unit is now unlocked.
Your version has a Dynamic Controls model controller and joystick. Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand) Turn the chair off, wait 5 seconds, turn the chair back. If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors. 3=Left motor fault 4=Right motor fault 5=Left brake fault (may not be engaged) 6=Right brake fault (may not be engaged) Any other fault code usually means the electronics or wiring is bad and not worth fixing.
If chair has a tilt, recline or lift seat on it it may be going into lock-out mode on its own due to a limit switch fault. If you don't have any of these options then I suggest you remove the joystick, controller and any wire harness between the two and send them to a shop like mine for repair. The usual lock out light chase is from left to right - not right to left so this is suspect of a different issue.
The chair should have a meter on the rear panel where the 9 pin connector for the joystick plugs into the chair when you plug in the charger cord the meter should move up and the lights on the joystick should flash indicating the charger is plugged in. When the chair is fully charged the meter should read zero or bounce up and down. Hope this helps
sounds like a charger inhibit problem. Whenever you charge your chair the charger inhibit shuts down the chair so it can't be moved while charging. If you are getting this then that function is not working. Lets try this if you know of someone who has a chair or scooter with an off-board charger see if you can borrow it. Plug the off-board charger into the charger port located under the front of the joystick (don't have the on-board charger plugged in) and then turn the charger on. turn the chair's power on and you hopefully will see the lights blinking again indicating a charger plugged in (charger inhibit) the lights on the charger should be red and yellow (yellow turning green when fully charged) If you still get the problem with the off-board charger then your problem is in the controller or power module and this requires a new one. If Medicare paid for your chair you can call Repair Xpress @ 1-877-81-3733 or Roadrunner Mobility @ 1-800-467-2668 to have them fix it for you and bill Medicare for most of the repair costs. Hope this helps you
Romp, Did you check the freewheel levers chair will not move if you are in freewheel. Levers are in front next to seat posts and need to be facing forward. If you are not in freewheel then check the number of lights you have on on the joystick and that they aren't flashing. Also check that your speed control is not on the lowest setting even with some charge a slow speed setting will not let the chair move. Now by some charge you mean lights in the green on the joystick? If the lights aren't flashing then I'm kinda unsure other than even with some charge the batteries don't have enuf current to drive the motors and need to be replaced Hoe this helps
The chair will not move if the charger is plugged in. The flashes are normal with the charger plugged into the chair. The lights on the charger mean that the batteries have been fully charged. Red and yellow lights mean charging. After you unplug the charger from the chair (if off-baord charger, turn charger off or unplug from the wall) then unplug from joystick. after plug is removed from joystick press the on button and all the battery lights should be lit and when you move the joystick forward you will hear the electric bake release and the chair should move forward etc Hope this helps
