Sony FD Trinitron WEGA KV-36HS500 36" TV Logo
Posted on Jun 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony kv36hs500 tv, suddenly no power, no standby lights, no sound
Hello i have a sony kv36hs500 sony trinitron television. About a year ago I had an issue with the tv not turning on and the stand by light that blinked 6 and 7 times..... I had a repair company fix the problem and the tv worked great. A couple of weeks ago i tried to turn on the tv and nothing happened, no standby lights no sounds, nothing..... I unplugged the tv for a few days actually almost a week and when i plugged it back in it was still the same, nothing happens......can you help me?
Chi Chu
Level 3:
  • Sony Master 8,457 Answers
  • Posted on Jun 15, 2010
Chi Chu
Sony Master
Level 3:
Answers
8457
Questions
0
Helped
2820362
Points
26282
U check the power source?Take the tv aparts,check or replaced the power fuse,might get lucky.Not,than sorry,this tv can't be repair,without replacing electronic's componnents parts.Hire the same shop to do the repair.Ur tv power ICS inverter are dead.
Sony Trinitron KD-28DL10U switched off suddenly to standby mid programme and won't come back on.When trying the remote on I can hear it click on and immedietly off again.Switched off at set and socket and...
Hello
In time as the Sony Trinitron ages it begins to have power issues. While this can be true of most tube televisions it's the rate and severity at which this happens to Trinitrons that makes it particularly of note. Many Trinitron owners have complained of the Trinitron set turning itself off randomly and frequently. Some sets have failed to stay on for longer than a few minutes at a time. Eventually some sets will not turn on at all. These problems grow more severe with age.
Check the power cable running from the Sony Trinitron 32. Make sure the cable is completely inserted into the power connection on the rear of the TV as well as the local power outlet.
Disconnect the power cable from the electrical outlet, then plug it into a different connection. It is possible to electrical outlet has died, forcing you to obtain a power current from a different source.
Check the cable connection running from the cable/satellite receiver or VCR. If the TV is on but no picture is on the screen, the problem is most likely due to a connection issue.
Power off the cable/satellite receiver, then press the "Video" button on the remote control to switch the Trinitron 32 to the video input signal. Turn on the cable/satellite receiver and the programming now loads onto the television screen.
6helpful
No picture, no sound
The power supply is not starting up. The most likely cause is two defective integrated circuits in the power supply section. If you are technical, I can supply you with the part numbers and where they are located.
I have a sony trinitron kv36hs500 tv which power problems
try making resolders on power supply ckts, try also adjust screen voltage,, check crt socket,,if all of this dont solve it, try to rejuvinate the crt.
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Sony trinitron kv-36fv26 (2000) tv wont show picture
Trires unplug,replug about an hour later see if it reset it self.Not take to the shop the two power ICs help the power it dead.Need it replaced.
Sony KV36HS500 won't turn on
3 times blinks shows problem of failure of IC6505 in DZ board. If you know basic electronics, open the back cover of tv and go ahead.
Sony Trinitron
I am having the same problem my tv will not turn on all of the sudden, standby light flashing, cnnot get it to do anything
Trinitron kv32s42
Can you tell me how many times red standby light blinks?
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
