It needs to "warm up " or something before it turns on. 80 % of the time when it turns on, the screen is spotty with a lot of tiny pixels scattered through out the screen. Is this problem fixable and affordable ??? Or should I just donate it .
H:H 80 on a Miele microwave indicates that the microwave's Keep Warm feature is in use. To end the cycle, open the microwave door or operate a selector or sensor (press a button (not the time display) or turn the selector knob). The keep warm setting runs the microwave for 15 minutes at 80W power starting 2 minutes after any program that used more the 450W of power. You can turn off the Keep Warm feature completely in the microwave settings. To change the setting, touch the menu button (arrow and three horizontal lines). Press OK and turn the selector knob until you see P9. Press OK and then turn the selector knob to change the setting. Press OK to save.
Capacitores on the power supply board have gone bad to low heat rating. Need to replace the Caps with higher rated ones from 80 degrees cent. to 105 degrees cent.
this issue is typical for capacitor failure internally in he Monitor, it can be fixed, it will require soldering internal components let me know what you want to do
When I turn on my computer the monitor takes a long time to warm up and colors change and vertical lines flash across the screen from right to left before the screen becomes normal again. Now the power light even goes out upon turning on my computer and I have to unplug the video cord and plug it back in to start the screen back up which even takes longer.
