Televison & Video Logo
Posted on Apr 13, 2008
Symphonic TV/VCR/DVD I'm trying to connect TV/VCR/DVD For a newly bought DVD. I was told by the DVD Manufacturer/Philips, to ask what input channel do I use for my Symphonic TV.
A
Anonymous
How do i hook up my new cable box for descrambling to my vcr
If the cable box has audio and video outputs on it then use RCA type cables to connect the outputs of the cable box into the video and audio IN of the back of the VCR. Then select L1 on the VCR. If your TV has video and audio input connectors connect another set of cables form the VCR OUT to the IN puts of the TV, then select the AV inputs on the TV. If your TV doesn't have video and audio inputs, then use a coax cable from the RF/Antenna OUT of the VCR and connect it to the antenna jack on the TV. Now select 3or4 on the VCR to whatever works for your location and tune the TV to that same channel. That's it ...you now can watch and record the channel you're watching. You will have to have the VCR powered up all the time to watch TV
2answers
I have Time Warner cable. I have a Symphonic SR90VE vcr/dvd that I have hooked up to the main TV. The cable box services a second tv in another room. I can't seem to get the main tv and the vcr/dvd player...
Cable goes to vcr cable INPUT, then run cables from vcr OUPUT to tv INPUT or AV.
Then put tv on input or av channel or channel 4 and use put the vcr on the channel you want to record.
2answers
I have a Magnavox ZV427MG9 A VHS & DVD Recorder
U must make sure ur tv channels must work throught ur DVD and VCR unit.Then u can record it out the tv show programs.U must connect the tv air signal or cable to the DVD VCR unit in the antena port.Use another cable connect out on the DVD &VCR unit and in the tv signal input in ur tv antena input.Make sure u in the channel 3 or 4 switch desire back of the DVD&VCR of the back,and the tv correct to ur desire channel switch to 3 or 4 .U
can record tv shows now.
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
Dvd hookup to phillips tv without inputs
Have yourself a VCR that has a Scart input, or Video in, and feed the DVD in there. Connect your TV to the VCR, and tune it in to the video channel, using aerial lead and tuner.
When you flick VCR to AV1 (or similar) you should see the DVD appear on the TV Video Channel :)
No signal
You need to find which is the right channel. It is usually AV2. However make sure you plugged in all the cables to right places. Also, call your cable company and ask them which channel might be, since this new HD tv are so different.
One more thing, If you have a VCR/DVD connected to the TV, you need to check the channel of the VCR/DVD
Artgirlny
DVD operation
scroll down on the channel button from channel 2. the different aux inputs should be there.there may also be a video/line in/source button on the front of the tv.if there isn't, you can buy a cheap universal remote for under $10 [even in some dollar stores for $1]
wg
DVP334V cant connect to my LCD TV
  1. Connect the video cable to the players VIDEO (CVBS) OUT (yellow) jack and to the TV's VIDEO IN jack.
  2. Connect the audio cable to the players 'AUDIO LEFT' (white) and 'RIGHT' (red) output and the TV's 'AUDIO LEFT/RIGHT' input jacks.
  3. After it is hooked up, you will need to select the TV’s video input channel that corresponds to the jacks connecting the player to the TV.
    • Press STANDBY-ON to turn on the player.
    • Turn ON the TV.
      Note: Video Input selection varies for different brands/models of TVs. Consult the user manual or manufacturer or your TV if none of the below is successful.
      • Press channel 2 on your TV. Then press the channel down button to locate the video input channel. (This channel is usually located between the lowest and highest TV channels.)
        OR
      • For some TVs, there may be a button on the TV’s remote control that accesses the video input channel labeled SOURCE, AV or SELECT.
        OR
      • Select the Video Input Channel from the TV’s on-screen menu system.
Composite Video Connection. (Example Only)
051104165152_4352.jpg Attachments
    No attachment available.
Connecting to a DVD/VCR player/recorder
In the menu of the Philips dual unit,select set-up then look for channel auto-program instructions. Be sure to hook-up a tv channel signal source before beginning auto-search.Hope this helps.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
