Hi
Thanks for using FixYa. The issue is with the convergence ICs going bad and needs to be replaced. It’s not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. To start with you’ll have to open the back of the unit and then replace the ICs(STK ICs) which are located behind the black heat sink and also check the resistors as if they are short the ICs might blow again after sometime. There are repair kits available which includes repair instructions with the parts, if you want to do it yourself you can buy and repair it yourself. If you want to take assistance from a professional then please click on this link to contact a local authorized repair center in your area. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Thanks Rylee. Do you know of any good technicians that would be willing to come out and make the corrections? After the Frick's guy came out, I really don't want to pay for another service call unless the price is reasonable.
You can take it to your local repair center or click on this link to locate authorized repair center in your area. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Thank you for using FixYa!
I hope that I helped you & that this post is helpful to you at most!
Don't forget to rate! :)
