SOURCE: Wireless connection fine but internet connection impossible
if you only have usb connection in your modem, internet on the zyxel router will not work since it's using ethernet connection. in order for your zyxel device to work with tiscali, you will need a cable/dsl router that has ethernet connection as well. you can contact tiscali if they can provide you with that kind of modem.
hope this'll help you
ciao
SOURCE: Laptop does not detect wireless from Zyxel 660 router
Disable the network adapters on the laptop via device manager and then enable again. If this does not work reinstall the network drivers and see whether it helps.
All the best!
SOURCE: Wireless Problems Zyxel P660HW-D3
When you defined the name for Wireless connection with you new router, did you give it a new name? If this is a case then you can delete the old name in your available wireless network list in your lap top so it won't go back to the default one which is the old one, then you are all set.
