I'll give it a shot. Have you tried re-regestering the handset? Press and hold down the "end" key (on most models it looks like a red handset) while holding that key down, press and hold the # key, after a few seconds the unit should beep and show:
(SYSTEM RESET)
Deregister HS
BaseUnavailible
Useing the four-way key select "Base unavailable" and press the menu key The LCD display should then show :
"Which Base?"
Base #1
Select base one and then the display will show
"Base Unavailible
Yes
No
Select "Yes."
Your handset is now unregistered. To re-Register the phone to the base do the following. If the base unit has a charging cradle, just set the handset in it and it should register on its own, if you have a cordeed base, or the unit will not register when you set it in the cradle on the base go to menu and select register handset, then press and hold the # key on the handset for 2 - 3 seconds, it should beep and then start the registration process. If you have 6 handsets registered to your base, you will need to de-register teh non-working unit from the bases memrey before you will be able to re-register the handset.
Testimonial: "The instructions were very complete and easy to follow."
After doing what Guru says to do if your unit doesn't re-register, then, if you have a base unit that plugs into an outlet, unplug the line on the back of the unit next to the telephone line. Before plugging back in hold the on-off button and the clear button (the circle with the line through it) down and plug the line back in at the same time. A "P" should flash on and off and the 0 showing no messages will come on. Set the handset in the cradle and it should now reset.
If you are with in what you think is a reasonable range ... your batteries are probably just about done for ... replace your batteries.
what is your expectation of me?
You could have revealed these very important facts for your case at the front of the question, at which point I would have had a entirely different answer for you ... as it is ... you have rated me unsatisfactory for the question you asked ... I shant give you further chance to degrade my score further.
All the question catchers here are volunteer workers that make this site work, by the way ... generally speaking, collectively, we are very good at what we do when given proper opportunity and with proper questions.
Thank you for your interest in FixYa.com
new machine; new batteries, fully charged - DECT 1580-2
I have done all the steps suggested. Once selected base unavailable YES, it asked to set it on base for registration. I put Cordless to Base...It shows Registration Failed.... any solution to this? i have DECT 6.0
