Operator's manual for DW926K-2 is here. It doesn't specifically address solid red light, but that's what mine does when I first put it on, so solid red indicates that it is charging.
If it is flashing the red light with two fast blinks followed by a
pause. This means the power source has out of spec for the charger (such as a generator not producing electricity at 60Hz).
If the red light flashes long, then short, you're in Hot/Cold Pack Delay mode which means it won't charge the battery until its temperature has stabilized.
I hope this helps! If so, please vote. Thanks.
Testimonial: "I appreciate the info about the blinking red. It did eventually turn to the steady light and was charged. Unfortunately the link you set up for the manual was not the manual on the drill but for a planer. I would still like to access the drill manual. Thank you."
Sorry about that, here is the correct link to the user's manual for the DW926K-2.
