Refrigerators Logo
Posted on Jun 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
High pitch whistling noise - KitchenAid Refrigerators
Terence Fourie
Level 3:
  • KitchenAid Master 909 Answers
  • Posted on Jun 14, 2010
Terence Fourie
KitchenAid Master
Level 3:
Answers
909
Questions
0
Helped
375052
Points
2542
It can be either the compressor fan motor or evaporator fan motor. OR often if there is moisture in the gas line, there is a whistling or ghosting noise. If all is running well then you could just leave it until a problem arises
it until eventually the com
2answers
Why does my Rigid shop vac make a high pitched whistle with a long hose on it but not a short hose?
The high pitched whistle that you are hearing from your Rigid shop vac with a long hose may be due to several reasons. Here are some possible causes:
  1. Airflow restriction: When you use a longer hose with your shop vac, it increases the airflow resistance, which can cause a whistling noise. This is because the motor has to work harder to maintain suction, and the increased resistance can cause turbulence in the airflow, creating the whistling sound.
  2. Hose size: The size of the hose can also affect the whistling noise. A smaller diameter hose can increase airflow resistance, which can cause the same issue as a longer hose.
  3. Clogs or blockages: If there are clogs or blockages in the hose, this can also cause the whistling noise. Check the hose and attachments for any obstructions, and remove them if necessary.
  4. Vacuum motor issue: In some cases, the whistling noise may be due to a problem with the vacuum motor itself. This could be caused by a damaged impeller, a loose fan blade, or other issues with the motor.
To fix the issue, you can try the following:
  1. Shorten the hose: If possible, try using a shorter hose to see if the whistling noise goes away. A shorter hose will reduce the airflow resistance and may help to eliminate the noise.
  2. Check for blockages: Inspect the hose and attachments for any clogs or blockages. Remove any obstructions that you find.
  3. Clean or replace the filter: If the vacuum filter is dirty, this can cause airflow resistance and make the motor work harder, leading to the whistling noise. Clean or replace the filter as necessary.
  4. Check the vacuum motor: If none of the above solutions work, you may need to inspect the vacuum motor for any issues. If you are not comfortable doing this yourself, you can take the shop vac to a professional for repair.
Fan making high pitched whistle
check for debris in the air intake. I've had leaves in mine make a similar noise
Is a high pitched whistling sound at idle a vacuum leak or what?
hissing vacuum leak at idle, louder with open throttle ...
? 1:43
https://www.youtube.com/watch?v=tFoybr865n4
Jun 27, 2010 - Uploaded by fenixus
hissing vacuum leak at idle, louder with open throttle ... i know that my camera is poor and microphone suppresses high pitch ...Hi, my kia picanto engine also sound hissing/humming duringidling with open throttle. ... Loud whistling noise 2000 jeep wrangler 4.0l - Duration: 4:01. by Nasrac72 16,158 views.Missing: vt750c
A Whistle or metal sound with firing... - Honda Shadow Forums ...
www.hondashadow.net > ... > Technical Discussion
Jul 11, 2008 - ... under load (accelerating), that there is a small whistle or even 'tap on metal' high pitch sound ... Pics of my 2008 Shadow Aero 750 (VT750C ... loose bolt vibrating
Feb 29, 2012
High pitch whine
Jul 21, 2009
More results from www.hondashadow.net
Emits high pitched whistling after unit runs for 30 minutes
Sounds to me like the bearings are going bad in the motor. The hotter it gets the grease breaks down and the squealing starts.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
3helpful
What would cause whistling noise near pully and belt area noise gets louder with acceleration
The engine serpentine belt may be worn or wet. The belt slips, causing a high pitched squealing or whistle noise. The other possiblility is a bearing beginning to go out on one of your belt driven components
Gas Oven Whistling noise
I HAVE A NEW PROPANE OVEN THAT I CONVERTED TO NATURAL GAS. NOW I GET A WHISTLE WHEN I USE THE OVEN ONLY. DO NOT GET A WHISTLE WHEN I USE THE TOP BURNERS.
2004 ford freestar 4.2L engine...high pitched
this sounds odd but mine did this when i replaced the wipers. it seems the design of the wiper frame was making a whistle at higher speeds. the freestar wipers are exposed on the window cowl and not hidden so they endure the winds at high speed. it is worth a shot.
2answers
My car is making a whisling sound when started.
hi ,,two things 1- water pump. but most likely check your pulleys they will make that high pitch noise one of them fixing to go bad and what will happen the belt will jam and jump lose and will lose all power ,,cause you have one belt for alt and the water pump mostly its the pulley right under the alt ,,hope this will help ....Joe
1helpful
3answers
High pitch whistling noise in engine compartment of 2005 envoy
There may be a small hole or cut in a vacum line or possibly just loose. Also make sure the air filter box and the big hose to it are secure and clamps etc are tight. Pulleys and belts can make a high pitch sound also.
Top KitchenAid Refrigerators Experts
vince
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
