If you rotate the tub by hand, you can hear water sloshing like it doesn't drain all the water after the last cycle. We use the washer at least once a day so it doesn't have time to mildew but shouldn't it drain all the water out?
Water sond when tub is spun by hand is normal. there will always be wa terinside machine betwen tubs, maytag even uses a waterfilled tub ring for counter balance, totlly normal to hear. as far as mildew smells, use www.affresh.com
Thanks,
Makes sense to me that they would use water to counter balance the tub. Is this water sealed or does it move thru the pump each time to keep it fresh so it won't spoil and mildew?
Yes, I have the same problem but worse. No only there is water in the tumbler (normal) but it leaves the loads soaking wet. It started doing this about 2 weeks ago. What is causing this to happen? I've owned this washer/dryer combo for almost 10 years and this is the first major problem. Please help.
I understand that Maytag has a recall for this type of problem, is this correct and if soo why were we not notifyed?
I have been receiving a code of nd; does anyone else have this problem and if so, do you know what it means? Thank you. Frustrated in Arizona
water in tub ,is seal broken should not have water in it ,how to change seal
When rinse cycle is spinning toilet on 1st floor gurgles and won't flush. When rinse cycle is done clothes are not spun out.
