Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.
When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt,
press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)
The display should say line 002: appear only
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
MANY TIME A PERSON DIALS WITHOUT REALIZING THAT THE ACCEPTANCE CODE NEEDS TO BE INSERTED FIRST THE Nortel T7316E?...If you want to
temporarily turn them off use do not disturb (feature 85, feature #85 to
turn Do Not Distrub off) Turning off the ringing permanently will require you to program the set. Programming is done on M7310,
...regards John
