I've already typed this inof. I'm not sure if I need to do it again. My washer is flashing E:13. I tried the refresh cycle and checked all hoses but now the washer is full of wet clothes and the door won't open
Hi, i had an E-13 error code on my Bosch 500 series washer. The drain pump
impeller was plugged. Access the drain impeller at the bottom front
right corner. Just put a pen in the hole and turn the cover. Then you
need to manually drain the washer. I used a shop vac by just turning
the cap until it started to leak and vacuum the water as it comes out,
this takes quite a while. When you get it drained you can take the cap
completely off. When I did I found a wipe in the impeller. I took it
out and put it back together and the washer worked just as before.
Take care
