You need to check the voltage output of your power supply section.This power supply supply is a switching type power supply.there is a chopper transformer in there.its supply is a dc voltage unlike any other transformer which is AC supplied on the primary..First step.
1.Using a multitester measure the primary supply it is a DC voltage around 220v - 110 VDC
2.Measure the secondary output.The out put is AC voltage the supply for the B+ going to plyback is 115vdc the second output is 12v run through a regulator and the regulator lower the voltage to 5vdc.this 5vdc supplies the system IC and the jungle IC.this ic process the switching of the plyback transformer and the plyback transformers output supplies the voltage of the whole system including your relay in the degaussing section....once the plyback is activated the tv will now turn on...
good luck!Hope i helped you..
please rate my help..god bless!
Testimonial: "thanx, i'll check it out and i appreciate your time"
