Dean Edge 4 Bass Guitar Logo
Posted on Jun 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
New bass that has no sound when plugged in to amp.
Has new battery and would cut in and out until no sound could be heard
Fred Yearian
Level 3:
  • Dean Master 5,603 Answers
  • Posted on Jun 13, 2010
Fred Yearian
Dean Master
Level 3:
Answers
5603
Questions
Helped
2249823
Points
16163
Rememberthe switch for the battery is ACTUALLY the sleeve of your guitar cable. If the jack fails, the battery will not be connected. Unfortunately, these jacks take a lot of abuse. The jack is really a stereo jack and the connection of the "ring" of the Tip-Ring_Sleeve (TRS) female jack to the "sleeve" connection is what grounds the battery for operation.
Mistakenly using a stereo audio cable will also cause this problem.
Use a good quality instrument cable, preferably gold plated plugs. Bad cables cause a LOT of these problems!
  • Ken Forbes
    Ken Forbes Jan 25, 2014
    Thank you for the advice, Fred. My Dean Edge 5, about 6 years of age, had a symptom of static.
  • Ken Forbes
    I took the back plate off, inspected things. Seemed OK. There's 2 small switches on the circuit board. I reset them and the static is gone. But your advice sent me up the right avenue. Thank you again!
On my Accustic B30 bass amp the input jack is not working. Can this be easily fixed?
Have you checked the battery? Put a brand new one, if that's not the problem, take it to a reputable tech.
Jul 22, 2017 • Bass Music
I want to build an amp that will deliver a bass drum sound for the stomp box I built.
As a 40 year guitarist and repair technician I had to laugh at this until I thought about my younger days of starting out. What I see here is that you made a momentary trigger out of a stomp box that apparently had problems, that you think you can build an electronic bass drum to play it with. Is this correct? See, the amp only gives a bass drum sound ONLY if a bass drum sound goes through it. Amps only provide audio power to the input signal. Where to get you bass drum sound is what you need to find. I believe you are thinking of a sample. A sample is an actual recorded sound of a bass drum that you could actually trigger by stepping on that button. You could find this on most cheaper casio, yamaha, emerson, radioshack, keyboards or drumpads or any of those amateur toys. Most of them allow a trigger pedal to be plugged into it and operational. Now, after you find something with a bass drum sample that you can trigger with your pedal, that device should allow you to plug it into an amp to amplify it. I hope I didn't confuse you much and had a close perspective of what you tried to describe. Please let me know if I can help further.
Mar 10, 2014 • Music
2answers
Peavey tnt 115 blowing fuses
Very unlikely, sounds like it's faulty. Was this on plugging in or were you using the amp, and if so doing what? What is your supply oltage?
I have a Jackson bass guitar bought almost two years ago. We had a gig and I noticed that the sound is not good enough. I was thinking that it was cause maybe of electric low voltage. Until i lost the...
I would say, that it probably needs a new 9V battery. It had some time to gain some juice after the gig. If a fresh one doesn't help, then the problem could've been the equipment or power outlet distribution at the gig site.
What is wrong? my active bass whether i put a new battery in or not sounds passive no change whatsoever. quite a bit of the low end is severely missing. Schecter STARGAZER 5 bass.
That bass combines passive EMG pickups with an active preamp (which provides the bass and treble controls). Sounds like you are never getting the preamp to work, and if that is the case there could be numerous reasons...a dead battery...jack wiring that is broken (meaning the battery ground wire is not attached or is grounding out)...likely should see a tech, but that is a good sounding bass when working correctly.
1helpful
3answers
My line 6 lowdown 750 keeps cutting out when i play a low b on my bass
Protective circuits kicking in. You may be overdriving the preamp to a clipping condition the amp sees as a problem. If it is under warranty, contact Line 6 and see if this is normal for this amp. It should not be, but you never can be sure.
2answers
When i play a bit loud (not too much though just when the light blinks red on the hard play) the sirquit closes the amp for two seconds.can you healp me on this ?thank you very much
does your bass have active pick ups?
do the ratings on your amp match the ratings on your speaker?
are you using a pedal?
does your pedal have an output adjustment?
have the ground on your bass checked.
make sure you're using the right kind of cable.
and be sure that the outlet you're using is grounded.
2helpful
2answers
Dean edge bass quits
The wiring in the back is so very thin and the circuit board isn't attached to anything but the wires that are attached to it. I found two weak solder joints there and one in the battery compartment (you'll have to remove it to get to the solder joints). I don't know which repair did the job, but it's working for now, anyway. I'd like to replace the tiny wires but there's not enough room in that compartment. I, also, had to replace the 4 bridge screws with larger diameter SS screws months ago as ALL 4 were stripped. Thread too fine for wood that soft. Come on Dean, step it up a notch! The bass plays and sounds great.
3answers
Bass Guitar Keeps sound keeps cutting in and out.
There is an inconsistency in your text. You indicate that cables were swapped and problem still existed...
You said:... "i have tried using it on a different amp and still fine".
If you tried it on a different amp and it was still fine then the guitar is probably OK.
THEN your amplifier is in question as the root of your problem.
What is the amp you have? The guitar is the CB-42, but what amp do you have?
MANY intermittent problems with amplifiers are often with the input jack itself. These jacks are easily broken by tripping over a cable plugged into them.
My bass guitar wont connect to my amp.
Assuming that the amplifier is functioning properly, I suspect that the problem is either in the cord, the plug socket on the bass, or the volume control potentiometer. First, I would try another cord that is known to be in good condition (ALWAYS plug the cord into the instrument FIRST). Second, carefully remove the cord receptacle plug from the bass and examine the solder joints (check for loose wires). Third, carefully remove the plate that holds the volume and tone pots. Examine these controls for loose wires or faulty solder joints. CAUTION: If solder joints are found to be the culprit, care must be taken to correct this problem. If too much heat enters the pot, it can be ruined!
Dec 31, 2009 • Music
Top Dean Music Experts
ADMIN Eric
ADMIN Eric
Tahir Hussain
Tahir Hussain
umar waheed
Are you a Dean Music Expert? Answer questions, earn points and help others
