SOURCE: Wi-Fi drivers for Acer Aspire 4710Z for linux
The drivers for Windows can be used if no specific Linux drivers exist. There's a program within Linux called NDisWrapper which is designed to use the drivers provided for Windows XP in Linux. Refer to your particular distribution of Linux for the details on how to set up NDisWrapper from within your distribution (I've only done it in Ubuntu so have no experience of other distros)
SOURCE: wi-fi driver can't be installed for acer aspire 4710z in windows xp
i am not satify with this solution
SOURCE: problem with wifi driver for acer aspire 4715z
Welcome to fixya
try going to driversupdate.org and see if you can down load there program and try to run it ....it helps alot on the driver updates and things like that and it is easy to use
hope this helps out have a good day
SOURCE: Acer 4720z wi fi driver on xp Os
شكراااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااا
SOURCE: acer aspire 3000 wi fi problem
First you need to make sure the Wireless drivers are installed in the computer, aswell the Acer Related utilities. Then Most acer laptops have a button on one of the sides or on the top of the laptop to turn on the wireless.
To find out if you have the acer related programs installed, try pressing some of the buttons on the top of the laptop, that are NOT apart of the keyboard, they should open up acer or related programs, if noting happens the programs are not installed, one of the buttons is likely to turn on the wireless.
To check if the wireless drivers are installed press start -> run -> type: msinfo32 (OR press down the windows key and press R, then let go and type msinfo32 into the run menu that comes up and click OK)
On the program, left side, open up components from the + next to it, then find Problem devices from the list and click on it, on the right you will see a list of devices that are not installed or not working.
If the list is empty, everything is properly installed. and you should be able to get your wireless to turn on by pressing on the wireless button on the laptop, and then use your computer to connect to a wireless network.
If you need further assistance let me know.
