Epson Stylus C46 InkJet Printer Logo
Posted on Jun 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Epson C45 printer only print out yellow color.
When I print out an image or text with image, the only color that comes out is yellow. So even if the image has blue or red colors, only yellow appears on the print out. Thanks for your help. pieces54
Anonymous
Level 3:
Brigadier General:
  • Master 4,090 Answers
  • Posted on Jun 12, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
4090
Questions
0
Helped
1183258
Points
12747
Run a maintenance clean on it
r click on the printer icon go to properties, then seek the maintenance tab on the header of the print queue and run both clean and nozzle check. When all of colors print the problem is fixed.
In colder times leaving printer in ON mode keeps ink from hardening and blocking jets
Please rate my help++++Thanks for using FIXYA
Epson Stylus C45, does not print image on paper, ink cartridge are loaded, it load paper & function but no image print
Make sure you removed the plastic tabs from the cartridge heads and run a self test print.
I’m happy to assist further over the phone at https://www.6ya.com/expert/vincent_e64835e2b80feb5e
Epson stylus d45 prints purple images the yellow ink wnt come out
You have done most of the required DIY but I feel that two more things can be tried out. First of all you can reinstall after removing the sofware from your PC. there after connect the C45 and try to see if the fault changes. If not we have to suspect the head and since you had tried the maintenance and head cleaning which is inbuild in this model . You will have to think of the cost of an head assembly to the cost of a new model of epson. If not try to use it printiing all your documents till the ink runs out and decide. Hope my advice helps. Good day
2helpful
How can i use epson stylus c45 without black ink its urgent plz
If this is a color printer, then you cannot use it without the "Black" cartridge.
Most printer manufacturers will pull from the "Black" ink to print black on color images. They do this to save on creating a "processed black" from the color inks.
Just curious, are you using a "CMYK" system? (Cyan, Magenta,Yellow and Black inks)
Don
My epson c45 not printing the exact colors that is
I suppose that you have cleaned the heads to eliminate any clogging. In that case the Printer cartridges were probably refilled in the wrong order. Try using a new one and post again if it's the same.
My epson stylus c45 wint print yellow, everything else is good, please help me.
The yellow nozzle is badly clog, use head cleaner with syringe and flexible pipe to blow the yellow nozzle.
8helpful
7answers
Epson stylus c45
epson.com, actually you can print using black ink only, but you have to reset the color ink for it to register as full. :) or you can freeze the ink counter using the ssc service utility before the other ink rans out. :)
2answers
Ink
Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head. Therefore, once one of the cartridges are expended, the printer signals you to replace the cartridge in order for printing to continue.
1helpful
Printing without color?
Im sorry to inform but yes, Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head. Therefore, once one of the cartridges are expended, the printer signals you to replace the cartridge in order for printing to continue.
Epson Stylus C88 Printing Problem
print the test page and check its working or not and getting clearly or not set the printing level is normal then it prints slow , i think your image comes best try it or again post it
Does not print pictures
hi suvi please tell us more about your computer and printer setting.. However, i have some question.. 1) Does your printer print another logo or any other picture correctly like before? & 2) Which software did you used to print your logo? Thanks, waiting for your response
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
