HP Deskjet D4160 InkJet Photo Printer Logo
Posted on Jun 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I scan with the HP Deskjet D4160? - HP Deskjet D4160 InkJet Photo Printer
Anonymous
Level 2:
  • Expert 269 Answers
  • Posted on Jun 12, 2010
Anonymous
Expert
Level 2:
Answers
269
Questions
0
Helped
95053
Points
701
your HP Deskjet D4160 is do not have the scanner so you cant scan in this printer
Thank you for using Fixya.
Regards
Manish
5 Related Answers
Anonymous
  • Posted on Sep 18, 2008
SOURCE: HP DeskJet D4160
printed fine and then stopped. now the arrow light is flashing. i unplugged it several times to no avail. what is going on and how do i fix the problem?
MUKHTAR
mukhtar21 shaikh
  • 2022 Answers
  • Posted on Sep 22, 2007
SOURCE: HP PSC 1210 Xi won't scan
try to locate this file from drive software disk or re-install the setup. bye
Anonymous
  • 3614 Answers
  • Posted on May 28, 2009
SOURCE: MY PAPER IS JAM IN MY HP DESKJET D4160 PRINTER
Paper can jam inside the printer for a number of reasons.
  • Open the cover to the printer and look inside to see if there are any pieces of paper or debris that may be blocking the print path.
  • Be sure to unplug the printer before touching anything internal to avoid electric shock. If there is something blocking the print path, remove it, close the printer, and try printing again.
  • You can also check inside the printer to see if any components have come loose.
Anonymous
  • 677 Answers
  • Posted on Jan 01, 2010
SOURCE: how do I check ink levels on my HP deskjet D4160
Here is what I found on the Web. You can click on the link below, to see Full Instructions. If you find this helpful, pls rate me.
http://h10032.www1.hp.com/ctg/Manual/c00687555.pdf
View estimated ink levels
Follow these instructions to view the estimated ink levels of the print cartridges that are installed in the printer:
1. Open the printer Toolbox.
2. Click the Estimated Ink Level tab.
Note If the print cartridges were used before being installed in the printer, the
estimated ink levels will not appear on the Estimated Ink Level tab.
The Estimated Ink Level tab also contains print cartridge ordering information. To view
this information, click the Print Cartridge Information button.
Thanks and good luck.......
Pls rate me
Anonymous
  • 192 Answers
  • Posted on Mar 20, 2011
SOURCE: I have a HP Deskjet D4160 , worked fine until
This is a step by step solution.
Please let me know if it fixes the issue.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00635074&prodTypeId=18972&prodSeriesId=501868
Testimonial: "Tired many steps until I came to the test print, hold the power button on and at the same time the PhotoSmart express button, and the printer worked"
It is possible to use 93 and 92 ink with my HP Deskjet D4160??
The best place to find compatibility information for HP printers is at www.suresupply.com.
2helpful
3answers
Need software for hp desktop printer D4160
HP Deskjet D4160 Printer Basic Driver Installation Instructions:
1. Click on the Download Only button and a File Download box will appear.
http://www.nodevice.com/driver/Deskjet_D4160/get39222.html
Wont print no print dialogue box
Here's a link from HP website that will scan and try to fix the problem automatically. Also insure the driver installed correctly with software.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01072463&lc=en&dlc=en&cc=us&lang=en&rule=15233&product=501857
Need help installing my hp printer (Deskjet D4160) please help
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=501857&lc=en&cc=us&dlc=en&submit.y=7&submit.x=9&lang=en&cc=us
1helpful
Ip address of hp deskjet d4160 to add printer in network
For getting the IP address, first you have to check printer settings from printer LCD display panel. Or alternatively you can search for network connected printers and then install it.
HP PSC 1210 Xi won't scan after installing HP Deskjet D4160. Scan.msi can't be found
k24674
Grand Canyon Tech
Grand Canyon Tech
