Hi, the amps would be OK, but you have to have a 230 volt outlet to plug it into, or it will not run. There is no other way to do this unless you run a 230 volt line over to the window unit. You can do this from the outside of the house. This is all you can do unless you move the a/c to where you have a 230 volt plug, and I don't think you want that. This is the only way I am sorry to say.
Sincerely,
Shastalaker7
To install my A/C unit, I need a 15amp/230volt outlet, I could not find de outlet 15amp/230volt only 15amp/250volt or 20amp/250volt can I use it, and the wire # 10- 3. My a/c unit is 18,5000 btu
SOURCE: can I plug in a
The 20 amp would be enough for your AC as the initial current drain will be only when the motor starts ups and will reduce to about half on running.
So provided the AC has no fault of its own the present socket can be used and spcially if the socket quality -- must not heat while the AC is running.
