GE Spacemaker JVM1640SJ Microwave Oven Logo
Posted on Jun 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It is all of a sudden beeping and there is a -F3- in the screen area. What do I do. It is a above the stove microwave. And has never done this.
Oloyede Monsuru
Level 3:
  • Master 1,468 Answers
  • Posted on Jun 12, 2010
Oloyede Monsuru
Master
Level 3:
Answers
1468
Questions
0
Helped
407430
Points
4011
The -F3- is an error code indication temperature sensing error. There is a chance that there is a loose wire connection from it position.
what you need to do to fix up this problem is to unscrew (open)the oven trace the wire down to the screen and also to the panel clean then fix up the loose wire back to it position then clean up all form of water or liquid you can fine around the wire and the control panel with this the problem of f3 code is solve.
than you.
My microwave keeps beeping when plugged in and shows a F3 code on the screen. What can be done for this?
Possibly a sensor error.
There is a temperature sensor that is giving the wrong voltage to the control panel.
F3 error
So far so good we unplugged the machine took the filters off the bottom let everything dry out over night and it seems to be working I'll update you tomorrow. I think the steam got the control pannel wet.
F3 flashing on display screen..no buttons work!
I have the same problem. However when I unplug the microwave from the wall outlet, let it sit for 10 seconds, then weird codes appear on the top line. Reset the clock and it shold work just fine.
[email protected]
Spacemaker beeping loud and f3 message driving us crazy
The error code F3 indicates an oven sensor problem. The oven sensor is most likely the failed part. The oven sensor probe must have the correct resistance readings at specific temperatures. When the electronic range control (ERC) cannot identify the correct resistance of the oven sensor or the resistance is way out of specs F3 will display.
I recommend calling a service technician to diagnose and repair your oven.
1helpful
Replaced key panel for F3 fault, still not working
This answer assumes that the new keypad is the right one and that it is plugged in correctly.
F3 is normally a bad keypad, but it may be debris or residue on the circuit board in the area that the keypad plugs into, or there may be some corrosion on the connections of the keypad connector.
Look for whitish or dark green deposits on the circuit board. These may be mineral deposits or tarnished copper due to moisture.
These are most common if one cooks on the stove top without turning on the hood vent exhaust fan.
Feel free to post a good close up photo or two of any area you suspect.
Feel free to contact me directly for more information & help.
William E. Miller
[email protected]
http://www.microwavedisplay.com
The microwave suddenly beeped several times, the scroll directed to push clock button, but no button would respond and then F3 appeared on screen but no explanation. We unplugged microwave a couple of...
The code f3 is a short in the key pad for more than 60 seconds
go to GE .com and enter your model # and you can get a price to do it your self
Good luck
TEETERMAN
16helpful
2answers
Microwave shows F3
microwave quits working and F3 comes up on the readout - along with a series of beeps - pressing any of the buttons on the touchpad does nothing - The F3 stays there and beeps intermittently
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
