SOURCE: blackberry call barring
To disable call barring
1. On the Home screen, click the Phone icon. The Phone screen appears.
2. Click the trackwheel to view the menu, and then click Options. The Phone
Options screen appears.
3. Click Call Barring. If your SIM card is provisioned for call barring, the Call
Barring screen appears.
4. Select the call barring option that you want to disable and click the trackwheel
to view the menu. Click Disable.
5. Click the trackwheel to view the menu, and then click Save.
You return to the Phone Options screen and your call barring option is disabled.
SOURCE: my blackberry curve has a 1x but full bars and
the 1x refers to your data signal strength. It must say 1XEV to have full coverage. Full coverage allows you to email, txt, etc. It might be the area you are in but if travel around and no changes, check you connections. "Manage Connections", the icon is an antenna, make sure your network check box is checked. if so, scroll down to "mobile network options" and make sure your "data services are on". If it is on, power down the phone, and remove the battery for minimum 2 minutes, then put battery back in and turn on. if you data is still only 1x contact your service provider.
SOURCE: how can I change keypad
hello you can try setting it by using and holding down the a key on the phone. THE newest software should have change that for you .
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
SOURCE: is mixit posible on a blackberry 8520
Hey a can download my mxit but when a whant to open it says erre 11 I am celc pleas help
