Be sure to put the slide in the holder in the proper direction. The opening in the slide holder is rectangular, not square like the slide. If you place the slide in the holder horizontally and the holder window is vertical, it will crop off the sides of your picture.
Your scanner came with some software inside the box. If this is a second hand scanner with no additional software download the drivers from www.canon.com and run the software accordingly.
Mac os X does not require this process. connect the scanner to your machine and simply load the slides in the tray scanner and use the application "IMAGE CAPTURE" located in local_disk/applications/
The pictures automatically load and you select to crop or scan as is.
Later the image will appear on the desktop upon completion of scan.
For windows: I made you a link for your convenience:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=10242
I don't know if this is truly a "solution" or not, but I get the same thing on my HP 4850 scans. After scanning, I just crop the pictures to remove the black borders. Can you do that?
For unexplainable reasons, the Software seems to set it self to a crop of 17x1 pixels. Therefore, the files are small and the pictures essentially a small line. A reset of settings to factory defaults corrects this.
Scanned image is unsatisfactorily cropped
You can turn auto-cropping off or adjust how the image is cropped.
To turn auto-cropping off:
1 From your desktop, double-click the Lexmark X6100 Series
All-In-One Center icon.
The All-In-One Main Page appears.
2 Click See More Scan Settings.
3 Click Display Advanced Scan Settings.
4 Select the Scan tab.
5 Click Select area to be scanned, and then select a size from the
drop-down menu.
6 Click OK.
To adjust how the image is cropped:
4 Click the Scan tab.
5 Select Auto-crop the scanned item.
6 Slide the Tolerance bar to the left to crop less or to the right to crop
more.
7 Click OK.
