There are two different things that would cause a mouse button to stop working. The first is a with the mouse itself. The second is software related.
The software issue may just need you to update your driver or reset the mouse button's assigned tasks to the default settings. To do this use either the control panel or if you have software for the mouse use that and reset to the default settings.
The hardware issue is a different story. When you push the mouse button can you feel the faint "click"?
If not then the problem is the mouse itself. It may just need to be taken apart and cleaned or it could be that the small "momentary switch" is bad. I have replaced them but to be honest it a real hassle and requires a lot of electronics soldering experience.
I hope this helps and good luck.
