I have a coleman model 8333A8664 a/c unit on a fleetwood camp trailer and was wondering what watt generator would be needed to run it properly?
  • 6,674 Answers
Because it won't be powering just your AC, I would recommend 5000W. It's that big amp draw when compressor kicks in that will pull it way down, if not strong enough. Take for example the fact that a dedicated 20 amp breaker and cable are the norm for RV's to use for AC now. Double check also that the generator your purchasing will take a momentary surge draw of up to 20+ amps without tripping breaker on generator. I say 20+ because once RV is plugged in or wired to generator, it will be powering any other hydro operated appliances, lights, converter etc that the trailer has on board. I bought a cheapie rated at 4000W, and 3000 running watts, but it kicks out the breaker just trying to start my portable air compressor, rated at 15 amps.
Posted on Jun 10, 2010
6ya staff
SOURCE:
What kind of generator for a 1978 Wilderness trailer
1978 Wilderness Prices, Values and Specs Building travel trailers as well as fifth wheel trailers for the first time in the 1970s, recreational vehicle brand Wilderness designed as basic family vacationing and camping. Wilderness would also produce park model vacation units from 1994 to 2002 measuring up to 40 feet in length. A division of Fleetwood, Wilderness was discontinued after the 2009 model year.
Mar 27, 2017 | Televison & Video
I have an Ef3000iseb runs great here at or about 5000 ft. go up in the mountains it starts loading up and wont run. is there a higher altitude kit?
Yes thats true
there is high altitude re jetting in the carburator your carb has to be re jetted for the normal operation of the generator at high altitudes by the authorised personel but when you will bring it back again at the orignal altitude it will get heated quickly and may not function properly so you will have to bring the carb settings to its orignal position so be careful
Aug 12, 2012 | Yamaha Ef3000iseb Generator Portable 3000...
How do I connect 2 1850 watt coleman generators together to have at least 3500 watts to run my camping trailer?
It wont work. Electricity does not work like that. you can't double the power just by doubling the watts or amps. there is a lot and lots of other things involved.
I would rewire you camper so that half is run be one generator and the other half by the other generator... SO lights and fridge on one and plugs and heater on the other maybe...
Aug 13, 2010 | Electronics - Others
I have an old duo therm in a 1969 15'x8' travel trailer, How many watt gererator will i need to run it and maybe some lights? how and where do i check the watts or volts on it?
Lights take almost nothing to run, however, an A/C takes quite a bit to operate. It would help to know more details about the A/C unit you have, such as the amps it draws, how many Btu's, etc.
Another issue is how much noise are you willing deal with related to operating the generator, as some camping areas have limits on generator use and the noise levels.
That being said, if you're looking for a really good and quiet generator that will run your A/C and some lighting, I'd have to say you can't beat a Honda rated for at least 3500 watts minimum running watts. But those are pricey compared to other brands, which make slightly more noise when running.
If you can get away with more noise, then you can get a nice 5000 watt unit for around $500 +/- that should handle your needs.
Here's some info to help you in your decision making as to what you need to run your devices and you can decide what brand you want to purchase.
http://www.hondapowerequipment.com/products/generators/content.aspx?asset=gg_choose
http://www.lowes.com/lowes/lkn?action=howTo&p=BuyGuide/SelectGenerator.html
Hope this helps and best regards!
Aug 07, 2009 | Dometic Rooftop RV Air Conditioner
Need owners manual for 1995 Coleman/Fleetwood Niagara Pop Up Cam
This is a link to a pdf for the '95 manual from the Coleman site
Coleman®Camping Trailers by Fleetwood Owners Manual
http://www.colemantrailers.com/uploads/91731235052535.pdf
Jun 13, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Technical Question
A: Running watts are the continuous watts needed to keep items running. Starting watts, are extra watts needed for two or three seconds to start motor-driven products like a refrigerator or AC unit.
Aug 27, 2008 | Coleman Powermate Proforce 6,000 Watt 12...
7300 Series AC
***I guess nobody knows the answer. Ok. I'll search elsewhere.
Jun 14, 2008 | Heating & Cooling
Heating & Cooling Logo
615 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
