Epson Stylus RX425 Multifunction All-In-One InkJet Printer Logo
A
Anonymous Posted on Jun 10, 2010
I need to scan A document using an epson RX425 printer how do I do it #
Level 3:
  • Epson Master 6,688 Answers
  • Posted on Jun 10, 2010
Cindy  Wells
Epson Master
Level 3:
Answers
6688
Questions
0
Helped
3532742
Points
21745
It depends somewhat on your OS and the software installed you have installed. With a Automatic Document Feed, the pages need to be face up and the top edge forward in the feeder. On the glass platen, put the documents face down.
Open a TWAIN-compliant scanning application (XP, Vista and Win7 all have Paint which can acquire scans). Vista and Win7 also have Windows Fax and Scan. If you installed other software (such as that which came with the scanner), you would use that - Epson Smart Panel or ArcSoft Photo Impressions. Next open Epson Scan (this doesn't work with the Mac software so look at epson.com for Mac info). This runs the scan (and any specific resolution adjustments you make). It will generally launch when you hit Scan in the application. You can run Epson Scan alone if you do not want to edit the documents right away. Click Start > All Programs > Epson Scan > Epson Scan to use Epson Scan. In the Epson Smart Panel, you would click Scan and Save to start scanning or Scan with Options to adjust the settings prior to scanning.
If the Epson Smart Panel is installed and set up for it (including having a monitor running), you can also initiate scans from the scan button on the unit. Scan problems most often occur when there is a block in two-way communication. Try a new data cable and a different port. If you have a USB hub or print server, try a direct connection. The cable should be under 6' long for best results.
I hope this helps.
2helpful
2answers
My wife says it has a scanner. I say there's not - can't see a button. who is right?
Hi maggieandjef
Your wife is right the RX425 is a scanner. There should be a power on button but scanning is started via Epson Smart Panel software or a TWAIN-compliant application eg Photoshop, Office etc
Does this help?
Epson rx 425 is not compatible with wind 7 cannot add printer to pc
You should be able to install it using built-in drivers of Windows 7, using Windows 7 'Add a printer wizard'
If you have tried this and it does not work then you should refer to Epson, as they claim this is the correct procedure on their website.
You will need to download the Windows Vista version of 'Epson Scan' to enable scanning with your machine, however.
PRINTER EPSON RX425 NOT WORKING WINDOWS 7 ULTIMATE , IS NOT POSSIBLE FIND CORRECTLY DRIVER
Have a RX425 using with Windows7 the Easy range of software got the printer going but not the scanner! Epson contacted but said no its not supported for Win7 will need a new all in one. Not happy as RX is fully serviceable and happy with it. However I have found that downloading Epson Scan for Vista has worked .... who needs experts :-)
How do you scan a document on the rx425
I hope you have installed the MFD on your PC/laptop. If yes then do the following: Start the word processor (MS Word or whatever you use). Start the document and when there is need for the scanned document, insert the document in the scanner and go to File->Import. here you will get a choice of using the scanner. Do that. Alternatively, start the SW that got installed with the scanner. there you will find an option for Start Scanning..
I cannot scan text to worddocument
You have to use OCR (optical character recognition) program to scan text to word documents. Some printers come with this software, but some do not, and you have to purchase the software separately
1helpful
Button for paper feed on Epson rx425
Please put a blank document inside the scanner and do a standalone copy.
I cannot scan to windows xp from epson rx425 all in one printer
First switch off printer & uninstall everything including the printer drivers. Download the latest software from Epson Support site & reinstall. Link:
http://esupport.epson-europe.com/SupportHome.aspx?lng=en-GB&data=nKGrQtfEm6mIr17BBoUTdZr5V9BVmX64
How to get my epson rx425 to scan my paper work
If you are using the epson scan software
In the File Save Settings window, specify the file folder in which you want to save your scanned image. Click the Documents or Pictures radio button, or the My Documents or My Pictures radio button.
Select other then click on browse and locate the folder you created..
Update me if you have question
If it resolve your issue pls dnt forget to rate it as fixya. thanks!!
Microsft Vista doesn't support 4990 negaives scanning
trash and reinstall the epson scan software and download latest driver for your devices use this link support.epson.com and download drivers for win vista.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
