There is not a "fix" for this selection, MONO is basically a single channel output so there is no seperation for various speakers like left or right which is a stereo effect, mono is like a single speaker sound so you are fortunate to have the sound from 2 speakers but they deliver the same sound.
petersn67- Oh I understand now, how about when you perform a "speaker set-up TEST function" ie. the white noise level, that allows your to set individual speaker channel levels, if you are still only getting noise or sound from one single speaker then it more than likely is a hardware issue failure, last resort, maybe try resetting the microprocessor on the receiver, they usually trip from amplified overloads, just an idea.
thanks lynchms, but i should have elaborated more. i understand how mono output works. any other listening mode i set it on i.e. cinema, pro-logicII, etc. only outputs sound through one speaker. i was just wondering if anyone has encountered this and found something like a blown diode or a burnt up resistor. if so please share. thanks.
thank you lynchms. i will definitely look into that. again, thanks.
