Dear Carluc
Right for this one, it is essential that you unplug the oven from the mains and leave it to dissipate any electrical current certainly for 6 hours. Once you have done this, you wil to get yourself a phillips head 6mm screwdiver and unfasten the screws on the back that hold the casing cover to the chassis. This will expose the enternal components, then all you simply need to do, is find the lightbulb, unclip this from the holder and then replace it with one of the same make and model. Fitting and re-assembly is as straightforward as it is taking the unit to bits.
go to http://www.google.com and type in GE Microwave lightbulb........this will get you the details about the bulb, and use the same google search to get your service sheet/ disassembly guide. Easy as 1,2,3.
Hope this works for you and please contact me here if you need further assistance in this or any other matter that is of a technical nature.
Yours sincerely
Oz
I need to change the bulb inside the GE Spacemaker microwave oven (JVM1490SH 01). I cannot find where the bulb is located and can't find a removable panel panel that would give me access and that's after having taken off the front grill.
I too had a problem with the "over the range" halogen bulbs on my GE Over the Range MW oven (model PMV1870DM3)> I could not get the new bulbs to seat in their receptacles. I called GE and while the service person was very nice, no real solution was offered up except to say that the adhesive is only applied at assembly so the the bulbs don't fall out in transport. By holding up a mirror I was able to see how the bulbs are held in place. To install the bulb, insert the two prongs into the ceramic holder and gently push the bulb 'in straight'. A spring loaded mechanism will open and capture the two bulb prongs. Hope this helps.
Can I do what you recommend with the microwave still
fastened over the stove?
I have a GE jvm1842 microwave. I need to change a bad cooktop/night light bulb. According to the manual, I break an adhesive seal and remove the bulb by gently turning. I've never seen an instalation of a light bulb like this. The light bulb seal is broken, and the bulb just spins in place. I'm afraid to apply pressure as I don't want to break the bulb. I haven't purchased the new bulb yet. How would the I install the new one? Does it get glued in??
I need to replace the light bulb in my GE Spacemaker Microwave Oven. The Owners manual does not give me directions. Can anyone assist.
Bob
I have a JVM1631 microwave and I need to replace the night light bulbs underneath the unit. I pulled the light cover off and tried to remove the bulb but it twisted in place and the bulb came out with the plastic casing still attached, now I have a bulb hanging by its internal wires. There are 2 bulbs and both are blown. How do I properly remove these without
doing any damage to the bulbs or to the sockets.
The owner attempted to replace the light bulb (40 Watt, three inch) of an overhead light in a GE Spacemaker microwave (Model JVM1640) and broke the bulb causing an electrical flash. The other bulb stopped working-Is there an internal fuse that may have blown? I got the screw-in stub out but measured no current with an AC meter with the light on. Is this worth fixing or is there internal problems such as fried wires which make it worthless to proceed? Also why are these bulbs so difficult to unscrew?
