Omega 1000 Juice Extractor Logo
Posted on Jun 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need one of the clutch arms on Omega 1000 juice extractor replaced. I live in South Africa (Johannesburg) and so far could not find an agent. It broke off from side. The machine has been standing broken for 4 years now. Good machine, such a pity! Regards Christien
Alan Hood
Level 2:
Scholar:
  • Expert 195 Answers
  • Posted on Jun 10, 2010
Alan Hood
Expert
Level 2:
Scholar:
Answers
195
Questions
0
Helped
122738
Points
424
Hello Christien,
I would order a latch arm from Omega. they are around $7.00 plus change.
www.omegajuicersdirect.com
Regards
Alan Hood
amiman
UK
I have a 15 year old Omega 1000 that needs an arm replacement. Is it possible?
LOOK AT ALL THE OTHER JUICER`s they are not made that difffernt just put another drive on it and run the one that fits it !?
5helpful
My omega 1000 juicer won't turn on - I just bought it today.
Make sure it is assembled correctly and the latch arms snap shut completely
without any undue force. Also on the bottom of the juicer there should be a
reset button that might have tripped, just push it in. Other wise give Omega
a call.
How do you take the juicer apart for cleaning?
Undo the latch arms, remove the cover then the clutch nut in the center of the
blade. Everything should lift out.
1helpful
I cannot remove the broken latch arm on my Omega 1000 Juice Extractor to replace it with a new latch arm. I have tried to follow vague instructions on the web, but I cannot remove it. Thanks.
It's a real pain and even bigger pain to snap the new one in place. Best way to do it is remove
the 4 screws, not the center one, and separate the base. You will then have access to the
latch arm from within, but remember how everything goes back together again.
Hello! the top of of one of the arms has broken off about 2 inches at the top... is it fixable?
You can purchase new latch arms from Omega. Kinda tricky removing and installing them, but
it can be done. Have Omega walk you through it.
Latch arm broken on my omega 1000 juicer. I have ordered one. How is it attached?
Omega can walk you through it, but have a file handy because the new latch
arms are not a perfect fit for the older juicers. You might want to remove the
4 screws on the bottom to separate the base for better access. If you have
a little mechanical ability it can be done, if not it could get tense.
2helpful
2answers
Plastic arm bracket to hold bowl and cap in place while in operation snapped. Can I replace this piece?
wait if you have the old 1000 the new latch arm will not fit i tried it but if you the new 1000 go to omegajuicersdirect.com and find parts and email paula for info
3helpful
Need to replace latch arm omega juicer
First thing to do is call Omega and order a pair
at 1 800 633 3461 and also ask them for tips on
how to remove and install the arm. If your juicer
is older the new arms may not be an exact fit, and
you will have to do a little filing and improvising to
install them. Its helpful to remove the 4 screws on
and view of the situation.
1helpful
HI, I have omega 1000 juicer, and the latch arm was broken. I ordered the replacement latch arm online. I received my order today and there is no intruction how to replace it. I looked in omega 1000 manual...
There are no instructions. Call Omega 1 800 633 33461
for advice. Also new arms on an older juicer may not
be an exact fit so you might have to do a little filing
down on the arm to get it to fit. You can remove the
4 screws on the bottom to separate the base and get
a clearer picture of what you have to do. Basically
you have to pry the base of the arm away and push
up to remove it. If you're not handy you may need
some help cause it gets tricky.
One bracket broke. Tried to glue it with no success.
IF YOU ARE TALKING ABOUT THE LATCH ARM, YOU CAN BUY THEM FROM OMEGA AT
717 561 1105. TRICKY TO REPLACE. I REMOVED THE BOTTOM OF THE MACHINE AND
GAINED ACCESS THAT WAY. ONCE YOU SEE THE LATCH ARM SUPPORT PRY IT AWAY
FROM THE JUICER AND SLIDE IT OUT. CALL OMEGA THERE ARE 2 WAYS TO REPLACE
THE LATCH.
Top Omega Juicers Experts
john h
ADMIN Andrew
ADMIN Andrew
Aron
Are you an Omega Juicer Expert? Answer questions, earn points and help others
