Maytag MAH2400A Front Load Washer Logo
Posted on May 24, 2017
Sorry the model I have is MAH2406. I believe my
Sorry the model I have is MAH2406. I believe my model is a 5 kg model. I want to know what causes the washing drum to crack? My tenant tells me that the machine is an inferior brand. I told my tenant that it could be due to an over load. Anyway I have replaced the MayTag machine. Tenant is not happy with the answer. Still says they took care of washing machine. Wants to meet me in persopn to explain. I think it is a waste of time. So I need your answer to the damage. Patrick Khoo
4 Related Answers
Anonymous
  • Posted on Feb 14, 2009
SOURCE: I purschased a unit for
The Malber parts office is in Garden City, NY.
800 600 8913
The manager, Joel, is very helpful, particularly if you go there in person. I'd call first.
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Jun 10, 2010
SOURCE: washing drum broken what is the cause of a drum
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Above are your service and repair manual. below is a DIY self help troubleshooting site to assist you.
http://www.washerhelp.co.uk/diy-repair-help.html
A drum may have been damaged by an overload, but it is unlikely, as the machine would simply shut down and not run, you cannot Force a machine to work with an overload, these are NOT great machines, they are of "Lower" quality than many. This is a common fault.
Anonymous
  • Posted on Jul 01, 2010
SOURCE: Frigidaire Commercial Front Load Washer (coin op)
I have the same problem.. Did you solve it.
Anonymous
  • 4323 Answers
  • Posted on Jan 15, 2011
SOURCE: GE Top load washer Mod# WCSR2090G2WW Water
Hi
The issue is with the water level switch (part#10 in diagram) going bad and should be replaced. As the water flows in fine so the water inlet valve (part#805) seems to be working fine. Hope this helps...please post back for further assistance.
Daniel
Ounces to grams 1ounce to grams
How to convert Ounces to Grams How to convert Ounces (oz) to Grams (g).
Ounces to Grams ? Ounces to Grams conversion table Ounces (oz) Grams (g) Kilograms+Grams (kg+g) 0 oz 0 g 0 kg 0 g 0.1 oz 2.835 g 0 kg 2.835 g 1 oz 28.35 g 0 kg 28.35 g 2 oz 56.70 g 0 kg 56.70 g 3 oz 85.05 g 0 kg 85.05 g 4 oz 113.40 g 0 kg 113.40 g 5 oz 141.75 g 0 kg 141.75 g 6 oz 170.10 g 0 kg 170.10 g 7 oz 198.45 g 0 kg 198.45 g 8 oz 226.80 g 0 kg 226.80 g 9 oz 225.15 g 0 kg 225.15 g 10 oz 283.50 g 0 kg 283.50 g 20 oz 566.99 g 0 kg 566.99 g 30 oz 850.49 g 0 kg 850.49 g 40 oz 1133.98 g 1 kg 133.98 g 50 oz 1417.48 g 1 kg 417.48 g 60 oz 1700.97 g 1 kg 700.97 g 70 oz 1984.47 g 1 kg 984.47 g 80 oz 2267.96 g 2 kg 267.96 g 90 oz 2551.46 g 2 kg 551.46 g 100 oz 2834.95 g 2 kg 834.95 g 1000 oz 28349.52 g 28 kg 349.52 g
To convert 15:3 to kg
"15:3" is a ratio, "kg" is a measure of mass (or weight). Your question is like asking how to convert one-half to pounds.
Do you want to convert 15 lbs to kg? That would be about 6.80 kg.
Or do you mean 15 lbs 3 ozs? That would be about 6.89 kg.
Or do you mean 15.3 lbs? That would be about 6.94 kg.
Or, since 15:3 is 5, do you mean 5 lbs? That would be about 2.27 kgs.
WO KYA CHEEZ HA JO DRY HA TU 2 KG ,WET HA TU 1 KG,JAL JAYE TU 3 KG......?
Sorry, I tried Google translate but there are too many untranslated words : 2 kg dry, 2 kg wet; 3 kg?
How much air pressure to put in shocks with 2 riders
2006 Touring shocks =
Table 2-6. Rear Air Suspension Pressures
Shock Loading Recommended Pressures
PSI kPa
All Models Except FLHRS, FLHX - Standard Shocks
Solo rider up to 150 lbs. (68 kg), hereafter referred to as "Average" 0 0
Solo rider 150-200 lbs. (68-91 kg) 0-10 0-69
Solo rider 200-250 lbs. (91-113 kg) 5-15 35-103
Average rider with passenger up to 150 lbs. (68 kg) 10-15 69-103
Average rider with passenger up to 200 lbs. (91 kg) 20-25 138-172
Maximum GVWR (see Section 2.1 Specifications) 20-35 138-241
FLHRS, FLHX Only - Low Profile Shocks
Solo rider up to 160 lbs. (73 kg), hereafter referred to as "Average" 0-5 0-35
Solo rider 160-200 lbs. (73-91 kg) 0-10 0-69
Solo rider over 200 lbs. (91 kg) 5-10 35-69
Average rider with passenger up to 150 lbs. (68 kg) 20-30 138-207
Average rider with passenger over 150 lbs. (68 kg) 25-35 172-241
Maximum GVWR (see Section 2.1 Specifications) 40-50 276-345
111WWAARRNNININGG
Use this table as a starting point in determining suitable rear air suspension pressures. Do not exceed
maximum GVWR when loading vehicle and do not pressurize system in excess of 50 psi (345 kPa) for
FLHRS, FLHX models and 35 psi (241 kPa) for all others. Excessive load weight and/or air suspension
pressure can adversely affect handling and lead to loss of vehicle control, which could result in loss of life
Hi i want to know that a waight of 6 kg washing maching is a small one for cloths or it is ok . should i go for more than 6 kg. for 4-5 persons family. thanks.i just choose a whirlpool compact model of...
Your question is not easy to answer. An average washing machine is 8 kg. The smaller 6 kg will use less water and detergent, but you will be limited to 4 or 5 pair of jeans at one time...unless your children are small. A front loading machine may be a better choice for you. It can do very large loads, 12 kg, and still use less water and detergent than most top loaders, but be prepared to pay three times the price of a top loader.
1helpful
AEG SANTO No_frost refrigerator beeps with 5 sec freqency
We have the same fridge, and I could not find my model either!
The label is hidden on the bottom of the top part on the left side, you need to take the veggie tray out to see it. I spent about 3 hours finding the model on the net, and in the manual it said where to look lol.
This mysterious model is the AEG SANTOS 3895-6 KG AKA S3895-6 KG productnumber 928405123-- last two digits can be 00-33.
We had the same problem, solution: press and hold the ON button for minimum of 3 seconds. The fridge switches off. Wait 10 seconds and repress the same button. That´s the quick fix.
To make it go away completely switch off fridge, pull out plug, and thoroughly clean the air vents on the back below using compressed air. After this the problem went away permanently.
Good practice to airclean every 6 or 7 months. You can find the manual for the S3895-6 KG on http://www.electrolux-ui.com:8080
23helpful
4answers
How to calibrate a Pelouze model 4010 scale with a
when i turn on my 4010.the screen display shows 4010 but thats all it does.any solution.
3helpful
3answers
WHERE WILL I GET LG KG195 PC SUIT
Here you go dear friend :
http://lgmobiles.com/index_gsm.php
Just select your handset model and download the PC Suite for your handset.
Hope this help.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
