My sister had bought nokia 6300 its every thing is fine accept its battery life so tell me what is reason behind it?
Often the original batteries go bad, for whatever reason, I suggest you simply obtain a NEW Brand Name battery and install that, charge it up as per manual MOST IMPORTANT that first charge, then hopefully it will be all OK.
Before you do anything, please try it with another battery, if the other battery has the same problem, then there's internal faulty. Perhaps the charging ic. (Let's not guess, it the power ic). It can be modified, I would suggest you to get it done from a mobile repairing shop. Good luck. Thank you for using FixYa.
Try to replace a new and tested one..if still fast drain your nokia 6300 is shorted and need to remove the shorted parts..thanks
