Confirmed modelLinksys IP Phone SPA941 and SPA962 with SPA932
Linksys
IP PhoneThis document explains how to use Brekeke SIP Server with
the Linksys IP Phone SPA hard phone .
The Standard features include
two active line appearances, call forwarding, redialing, speed dialing,
transferring calls, conference calling and accessing voice mail. For
more information regarding this product please go to www.linksys.com
Configure Linksys PhoneSet
up your Linksys phone with a fixed IP address (e.g. 192.168.0.15) and
subnet mask (e.g. 255.255.255.0).
Once the IP address is
configured you can access phone webpage by its IP from web browser (e.g.
http://192.168.0.15).
Network SetupClick on "Admin Login", then
select “System" tab. Sign Static IP, Gateway and NetMask.
Use
the following data as an example
Phone ConfigurationSelect tab
Ext1 or Ext2 and enter SIP server information and sign extension number
or after
whole setup is finished
Use
the following as an example to complete the phone configuration.
type in the
same information at Auth ID and Password as what you set at SIP Server
side
and Use Auth ID: Yes
Brekeke SIP Server’s Registration PageClick
the [Registered Clients] tab at Brekeke SIP Server admintool.
The
Linksys IP Phone SPA941 Phone is registered with Brekeke SIP Server.
