Machine is unable to clean troubleshooting and routine maintain
The machine is stating..Unable to clean troubleshooting and routine maintainence is required as stated in the manual...however I do not have the manual...Thank you for your help!
If your your printer cannot clean automatically, your printer head is probably clogged so badly that you will have to do it manually.... your manual should tell you how to remove it...
From Brother: http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/000500/000065/faq000565_000.html?reg=eu&c=eu_ot&lang=en&prod=fax1840c_all
I have seen this too when the waste station is full. If this is the problem, it is likely time for a new machine or a reasonable repair bill.
You could check for a paper Jam or foreign oblect in the machine, under the top cover and in the back cover.
If there isnt a Jam in the machine it means there is a mechanical
problem. There is a sponge in this machine and once it is full it wont
be able to absorbe any more ink from the cleanings. You will need to
bring it in for services, they would replace the sponge and reset the
cleaning counter.
You can check the brother web site for an authorized service center in your area.
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this: Enter 80,
then scroll down with the arrow down (round) key. You'll find an
entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
