I dont have a problem i dont think but i dont know how to add the hardwere.this is my first computer and i dont have any sound for anything. The speaker system is hook up but my computer doesnt reconize it or doesnt show it. i dont know what to do. Please help .
you might have to uninstall then reinstall either the driver or the sound devices control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustmentsthere or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver hope this helps
well if you are getting a beep sound from your pc , then you may have a hardware problem , it could be your hard drive or anything else inside your computer ...eg ram or hard drive etc....the best thing id to disconnect any hardwere you may have put into the computer but disconnect them one at a time , and try to reboot ...you should only get one beep on boot up ...then your computer should work ok .... it seems that one hardware componant is not working or not installed properly.
first keep sound driver/cd/other in computer then right mouse click on my computer. then click property. then click hardwere. then look on device manager and right mouse click on speaker sign then u can see update driver ,click on it
computer depend on two thing one hardwere another softwer if hardwere damage it is not work any another computer . wierless system should be on computer.
click right mouse click harddware -divece manager look sound option (speaker sign} if not stall u can see yellow sign,install sound by using ur board cd. 2/ go run type control click sound andaudio option then u can get volum/sound/audio/voice/hardwer option check if incorrect correct it .3/ look ur speaker's volum is off or not? what u keep volum on mute or not? ..... thanks
first right click my computer then properties
scroll done and you'll see your audio in there somewhere
if it's there then click on it and update driver
if it is not then I can tell you how to add your driver again
http://drivers.softpedia.com/progSearch check here or you can use the Add Hardware wizar of your computer, just go to control panel and double click "Ad Hardwere" then follow the instruction, The compu will find the apropiate driver from the internet remember you have to be conect to the internet...Good Luck and rate me
