SOURCE: Clarion SIRIUS Radio Receiver - Not Receiving All Subscribed Channels
I am having the same problem, i was able to manually get about 37 channels by holding down the BND button which changed the mode to manual tuning which allowed me to manually move to individual stations. By going bak and forth I was able to add more stations, but once I got to channel 38 (which is not a used channel) I could not add more channels. I don't know if this will help you get a few more channels. I am going to try to call clarion to see if they can help, if you get it fixed, please post what you did. Thanks and hopefully we can get this fixed
SOURCE: Sat radio tuning question
You have to remove a memory setting in order to add a new one if you have six presets already set.
SOURCE: Sirius Receiver goes silent and displays Acquiring Signal.
I have a 3 year old Sportster 2 replay unit that worked perfect until 1 month ago. I posted my problem on this website a day before you did with this same problem. I googled to no end and even spoke to Sirius who wasn't willing to replace my unit at no charge since it was out of warranty. I found an unusual solution on the internet that worked for me. I place my receiver in the freezer for at least 20 minutes (this was recommended by a guy somewhere on the internet with the same problem). I have actually left it in freezer overnight too. This has solved my problem. It is the craziest thing but I thought I would try it before I resorted to replacing all my accessories and receiver since Sirius was less than cooperative with the issue. Anyway, hope this helps.
SOURCE: Satellite radio (REF) not connecting with Sirius.
how do i use factory satalite antenna on a dodge ram 1500 2006 for after market radio
SOURCE: My Sirius ST4 has signal issue after 10 minutes
This sounds like a component heat failure inside the unit on a circuit board. If it isn't in warranty, to figure out if that's what's going on, you can open it up and spray various components, one at a time, with Freon (Cool Spray at the Electronics Stores). When you hit the temperature sensitive part, the unit will work again. Go slow, and you should be able to pinpoint the bad part. Now the difficult part will be getting a replacement part, and if you're warranty's still good, better to let them fix it. I read where they're discontinued, so parts may be hard to get, and you might check Ebay for a replacement. Wish I had better news.
