We have extremely hard water in the East Mountains of NM. Our refrigerator Ice Makers only lasted about a year before the Calcium from the underground Calcium just killed them. I solved the problem by buying, from ebay, a small restaurant ice-maker. I Always fill it with filtered water, and it has been chugging away for years. Our water tested Harder than an Hot-tub maker had ever seen, even after going through our old, Sears, water-filter. Ergo - how hard is your water? Could that be the problem. Just a thought.
ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- In most of the cases the fault is water valve at the back of ice maker section, on some refrigerators the valve is at the lower section. ------------- The above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------ You can get required parts from sears part direct online site or from repairclinic.com site.
Does the ice maker get water? Could the fill line be blocked? I found on my freezer ice had formed at the end of the tube and once I removed the ice it has worked fine since.
ice maker is bad has it,s own timer built in to let water in if you have water to your unit ,,, be sure the little lever is down on top of the ice bucket. if it is up this will stop the ice making process this i s a device to keep the ice from over filling the ice bucket
bad water valve, thermostat, freezer not cold enough, make sure the ice maker metal rod is at down position or on back of the ice maker plastic water line is frozen. also depends what year combo you have, there operation is a little different.
I don't recommend repair on this unit. Simple replacement. Try to find Ice maker kit @ local home depot or lowes that is same. You can buy whole kit for $50-$75.00.
Hi make sure that the arm on the ice maker is in the down posistion as it will only put water in the ice maker in this posistion. It will take a little time to fill so be patient as the timer in the front on the ice maker needs to cycle first. Make sure you have connected it all correctly to...
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
I have a kenmore coldspot side by side model # 106.53662300.
The ice maker red light is blinking and it has made very little ice in the last 24 hours. What do you think the problem is?
Most common problem is a broken ice maker module. Should also replace ice maker thermostat when changing the module. Make sure fill tube isn't frozen first. If you take the ice maker out pull off the plastic cover and in the center of the wheel that kind of looks like a gear there are two little plastic studs. If one is broke or they are pressed together then the module is bad. Make sure to replace the thermostat along with some silicone grease because a bad thermostat is what causes the module to break.
